Contributing Member TwinOaks Posted April 13, 2009 Contributing Member Report Posted April 13, 2009 Also something very important to keep in mind: You should only be using about 3 feet at a time (for edge braiding). Beaverslayer mentioned that any more than that and the lace starts looking ragged after so many trips through the holes. Learn to splice in a new piece instead of pulling 10 feet of lace. It's also LOTS easier to keep straight. BTW, where is The Beave and his tinfoil hat? I haven't seen him in a very long time. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
Members Spence Posted April 13, 2009 Members Report Posted April 13, 2009 Spence - what is a bite tug? what is a muncher? Ray Ray - I'm sorry - I get to thinking everyone around me can read my mind. And even understand me. I raise and train German Shepherds for law enforcement types. Part of their training is to learn how to bite properly. I use an old section of firehose, filled with leather bits and pieces, then stitched at the ends. This give the "munchers" an idea what is expected of them. For puppies, I use a square of 5-8 oz leather tied on the end of a line to entice them into a chase and catch game. Whipstitch: 3.5XRunning Stitch: 1.5X Buckstitch: 2.5X Single Loop: 6.5X Double Loop: 8.5X Round Braid: 8X Johanna, thanks for that "cheat sheet". It will be going up on the wall here. Quote Spence Mendoza, TX, USA
Members rickeyfro Posted April 13, 2009 Author Members Report Posted April 13, 2009 Thanks for alll the responses. Johanna thats just what I was looking for, one more question, how much will lace width affect this formula, this is all about me wanting to try some 1/4 inch kangaroo lace, kinda pricey, will a wider lace take less to go the same distance? Quote
Members DCKNIVES Posted April 14, 2009 Members Report Posted April 14, 2009 Well, I'll throw my two cents in. I primarily use the Basketweave pattern in both 3/32" and 1/8". I will agree that with single layer or a double layer of say 6 oz. the 8X rule is pretty good. The problem that most of us that do sheaths and holsters have is that our edges can be very thick (3/8"-5/8" is pretty common).I have found for most of my stuff that 12X is closer to the norm. Also the edges are finished, glued, sanded, and burnished prior to lacing so the standard method of splicing won't work.So ,with that in mind I generally use one piece of lace.To help with the ragged edge syndrome I use a damp sponge to keep the lace clean and neat.If I am doing lace that is already dyed I will use beeswax instead of water.I would love to hear any other of methods of splicing that will look seamless.Dave Quote http://dcknivesandle...lademakers.com/
Suze Posted April 14, 2009 Report Posted April 14, 2009 dumb newbie question time have any of you ever started a lace in the middle - by that I mean pull your lace through to the halfway point and then lace from both directions. Quote Reality is for people who lack imagination Whether you think you can or think you can't - you are right. ~Henry Ford
Ambassador Luke Hatley Posted April 14, 2009 Ambassador Report Posted April 14, 2009 I did it once, going from left to right no problems but the other side i had to do it with the project upside down and had to lace backwards.. Quote Luke
Moderator Johanna Posted April 14, 2009 Moderator Report Posted April 14, 2009 I don't even want to think about double loop lacing upside down! I'd miss the whole movie! But you do start in the middle for a buckstitch, for example. The middle of your lace goes at the belt tip. Buckstitching is the only important "no splice!" lacing, unless you're going to hide it with a liner. Most of the time, like doing wallets and checkbooks and purses and so forth, you are better off splicing. The drag on the lace shows the wear after too many pulls. A good splice cannot be seen. You hide the ends inside the leathers when double loop lacing. If you must splice a simpler item, you can skive the ends of the laces and use a drop of leather weld. That's pretty much what they do at the factory anyway. I pull off a little more than an arm's reach from the spool, so I don't know how helpful the chart is going to be. These are estimates- your mileage may vary, of course. But learning to splice is a key to good lacing. Johanna Quote You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Members rickeyfro Posted April 14, 2009 Author Members Report Posted April 14, 2009 I do splice, I was just trying to estimate amount of lace to figure cost difference when using the 1/4" roo lace as opposed to other laces Quote
Members kevinhopkins Posted April 15, 2009 Members Report Posted April 15, 2009 I do splice, I was just trying to estimate amount of lace to figure cost difference when using the 1/4" roo lace as opposed to other laces Hi Rickey, the formula is pretty much the same, but you'll find that it will vary somewhat with every project, depending on thickness of the edge that you are covering, and distance between holes. Kevin Quote
