esantoro Posted September 1, 2008 Report Posted September 1, 2008 I'm running low on contact cement and am thinking of changing from Duall #88 to something else. What I like about Duall #88 is that its fumes aren't that strong. Any replacement will also have to have light fumes. My replacement choices are: Masters Barge,though I think this one is out due to strong fumes, which I've read about. Dural Dura-Safe non-flammable. I can get this for a good gallon price and like that it is nonflammable, but am not sure of its holding power. I mainly need contact cement for prepping two-sided straps. I would use Fiebing's white glue, which I use for everything else, for this, but for straps it's just too messy. Thanks for any suggestions. Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Ambassador Luke Hatley Posted September 2, 2008 Ambassador Report Posted September 2, 2008 (edited) Hey Ed. glad to see you back. yes straps can be Messy. I you were going to change brands of glue i have always liked and uses Masters, I have had no problem with it. also there is the New Contac Cement at Tandy I do like it also **************************************************************************** ED RE FRESH MY MEMORY, DID YOU HAVE AT ON TIME PROBLEMS WITH SEWING AFTER YOU GLUED SOME ITEMS? Edited September 2, 2008 by Luke Hatley Quote Luke
esantoro Posted September 2, 2008 Report Posted September 2, 2008 Hey Ed. glad to see you back. yes straps can be Messy. I you were going to change brands of glue i have always liked and uses Masters, I have had no problem with it. also there is the New Contac Cement at Tandy I do like it also **************************************************************************** ED RE FRESH MY MEMORY, DID YOU HAVE AT ON TIME PROBLEMS WITH SEWING AFTER YOU GLUED SOME ITEMS? Hi Luke, How are the fumes with Masters and the new Tandy contact cement? Do you happen to know if new Barge formula has less intense fumes? Ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Ambassador Luke Hatley Posted September 2, 2008 Ambassador Report Posted September 2, 2008 Masters has the fumes.........the Tandy is milder and the New Barge, is different i do not like it. Quote Luke
esantoro Posted September 20, 2008 Report Posted September 20, 2008 justwakinup. can you get the" TannersBond Contact "at your Tandysif you can you will be very pleased with the product, I am. I remember using Tandy's contact cement two years ago and was impressed by it. Because I had found Duall 88 cheaper, I switched. Now that the 88 is more expensive at $13 a quart, I just ordered 8 quarts of the Tandy at a dealer price of $32 for a gallon. I expect about $10-$15 for shipping. ed Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Members ryano Posted December 3, 2008 Members Report Posted December 3, 2008 I use Barge Cement. I get it from local Amish for $10.60 a quart. Works great, but boy does it stink. Quote
Bree Posted December 3, 2008 Report Posted December 3, 2008 I have Barge which I get by the gallon at Weaver and a quart of Tandy Tanner's bond lying around as well. I prefer the Barge but can live with either one. I have a gallon of some 3M Contact Cement that I use for laminates in woodworking projects but I have never tried it on leather because it is blue. That scares me a little. It does a great job of holding down that laminate! Quote Ride Safe! Bree 2003 Dyna Wide Glide Memberships: Iron Butt Association, Niagara Falls HOG, Wild Fire HOG NRA, Niagara County Sportsman's Association
Slickbald Posted May 12, 2010 Report Posted May 12, 2010 I don't care for the new Tandy/Barge cement either and will likely try the Fiebings. Has anyone found a comparable "snot" to replace the old Tanners Bond? Quote Chris Andre Slickbald Custom Leather Maker's Leather Supply (.com)
Contributing Member JLSleather Posted May 12, 2010 Contributing Member Report Posted May 12, 2010 I use Cobbler's Choice Cement, which I buy from S-T Leather. 20 years ago, it was half the price of the Barge's and worked well. Now it's about the same cost (at $13.95/qt) but I trust it so I still use it. Somebody said you could tear the leather trying to pull it apart, so I had to try .... they were right, you WON'T get it apart. And since I order other stuff there, it saves me time, trouble and shipping charges. S-T Leather Co P.O. Box 78188 St. Louis, MO 63178-8188 Phone: 314-241-6009 Fax: 314-241-8428 Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Moderator Art Posted May 12, 2010 Moderator Report Posted May 12, 2010 Masters. And I'm pretty sure Barge and Masters reactivate with heat, well the old Barge did. I have also used Renia Colle de Cologne which I like a lot. It is a German product. why they don't call it Leim aus Köln I don't know. Art Quote For heaven's sakes pilgrim, make yourself a strop!
