Members Davm Posted August 31, 2018 Members Report Posted August 31, 2018 On the dye, any tips on keeping such a straight line on the edge? Quote
Members Dwight Posted August 31, 2018 Members Report Posted August 31, 2018 2 hours ago, Davm said: On the dye, any tips on keeping such a straight line on the edge? Practice, . . . practice, . . . practice. Use old scrap leather pieces, . . . practice on them and pitch them. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members Professor Posted October 20, 2019 Members Report Posted October 20, 2019 My two cents on this old thread. First few holsters and sheathes I made i used the old timer method of applying egg white and burnishing by hand with the rounded corner of a wooden belt stripper or a dowel rod. Bone is another option. That works surprisingly well , at least when you want a rustic and natural looking finished piece. If the result doesn't suit your tastes its easy to go over it with a commercial edge dressing. Quote
Members sbrownn Posted December 2, 2019 Members Report Posted December 2, 2019 On 1/4/2017 at 11:45 AM, bikermutt07 said: I know this is a really old post but I'm gonna try it. I do something similar but I always try not to sand. The nicest edge for me seems to occur right after the knife cut so I cut, bevel and burnish. Sanding for me just raises a bunch of fibers up. Quote
Members sbrownn Posted October 28, 2020 Members Report Posted October 28, 2020 I never, ever sand leather. Sanding raises fibers which then have to be dealt with. I find that if I use a sharp knife to do the final edge cut and a sharp edger to finish off the edges no sanding is necessary. In fact sanding ruins the nice cut edges. For final steps I finish off with Tokonole, a dremel burnish and a final hand rub with canvas and liquid wax. Quote
Members 1961Mike Posted February 9, 2021 Members Report Posted February 9, 2021 Hi I have had to sand the last two belts that I made on the flesh side because they were so rough. Sanding in one direction worked well. I'm relatively new at this sport, but I found out yesterday that using cheap leather can lead to interesting problems. I found a soft spot in the leather and you can't burnish a soft spot. This was 6-7 thick leather. This was for a practice piece, so I"m not that concerned. later Quote
Members Davm Posted April 1, 2021 Members Report Posted April 1, 2021 I'm always unhappy with my edges. Couple of questions. One dying the edge- I take my time but how do the rest of you get an even, straight line? My belts are coming along pretty good now but the holsters are still tough. On the wood wheels under power- it seems most go that route and I think I'll do that as well. I take it from others that they are looking for a machine to give them a perfect job but is edging a task accomplished by machine or is it a task that simply requires an artistic touch? On a wood wheel- how do you keep canvas in place? Thanks to all. Quote
Members sbrownn Posted April 2, 2021 Members Report Posted April 2, 2021 9 hours ago, Davm said: I'm always unhappy with my edges. Couple of questions. One dying the edge- I take my time but how do the rest of you get an even, straight line? My belts are coming along pretty good now but the holsters are still tough. On the wood wheels under power- it seems most go that route and I think I'll do that as well. I take it from others that they are looking for a machine to give them a perfect job but is edging a task accomplished by machine or is it a task that simply requires an artistic touch? On a wood wheel- how do you keep canvas in place? Thanks to all. I've almost completely quit dying edges at all. I think that slicked and polished undyed edges are quite appealing. That's not to say that some of the dyed and polished edges aren't very pretty, because they are but why cover up the "natural" look of the leather? Quote
