Thank you.
  • Replies 134
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I've received several emails regarding this thread and so i'd  thought I'd  weigh in. There is absolutely nothing wrong with wetting the leather and then tooling it. To me that is sort of the norm and I often do that myself. The advantage to casing, as some of you have mentioned, is to (1) aid in cutting, (2) extend tooling time, (3) aid in the "burnish" or color you  get with the tools. It is not necessary to case overnight. The process can take just a few hours, which is depedent upon the environment. Many of us case over night because it's convenient to prepare tomorrows leather, today. Also, it is not necessary to use the refrigerator. The only reason to refrigerate is to prevent mold growth. Mold growth only happens when the leather has been too wet for too long in a warm environment. Finally the true differnece between cased leather and wetting the leather is this. Leather is cased only when ALL the fibers contain the same amount of moisture when the leather is in a TOOLABLE state. To achive this, the leather must be placed in a super humid environment, where evaporation has been slowed to a crawl. So SOME evaporation is required. This is why casing boxes work better than plastic bags. If you are using a plastic bag, it's necessary to let the leather dry somewhat before it is sealed in the bag. Old coolers make good casing boxes, especially when small adjustable vents are added to the sides and top.
I hope this is helpful and Happy Holidays, everybody!
Bobby
On 12/15/2016 at 8:04 AM, JenGranger said:
I have the same question about small projects.
Bennie Lovejoy & JenGranger...
Your logic is fine. As I've stated before, casing is not a requirement to produce better work. It's just another "arrow in the quiver" so to speak. Will casing small pieces of leather provide a better result? Probably, but that's something only you can really answer thru trial and error. You know a lot depends on your particular environment, the quality of your leather and the difficulty of the tooling pattern. You may very well discover that when doing small pieces that you can finish in a single sitting, just don't require casing. I think it would be a good idea to try both methods and then evaluate the results. As far as having inconsistent impressions goes, i'd have to see exactly what you're referring to. In general inconsistent impressions can be caused by a number of things such as moisture content, quality of leather and inconsistent strikes. Tool quality can take it's toll also!
Hope this helps!
Bobby
Thanks Hidepounder!
  • 1 month later...
Thank you so much for all those valuables information Hidepounder!!
I've tried to let my leather ''case'' longer, at ambient temperature (small piece,max 8*4 inches, over a 3-4 hours time),instead of tooling them right after wetting them and letting them absorb the water. It did wonder on my last piece.
The burnishes are finally showing!
I've wet my last piece yesterday, and have put it in a ziploc bag overnight, since i'll be tooling it tonight.
Do i need to let it dry for a 3-4 hours as i usually do , or will it be tool-able quite quickly since the job has been done overnight in the bag?
Thanks again!
*an amazed newbie
It depends entirely on how wet it was when you put it in the plastic bag and the humidity in your environment. If it had turned partially back to it's natural color, then it should be toolable soon. But if it was very wet when it went into the bag, then you will have to wait and it won't be properly cased. To case properly, the leather has to breath a little but must remain in a super humid environment while it returns to color. Old ice chests make good casing boxes, especially if a couple of adjustable air vents are installed.
Hope this helps!
Bobby
  • 1 month later...
I dipped a piece of dyes leather for 4 seconds into cold water and it took 12 hours to come close to normal color and the imprint isn't deep. The leather left the granite surface plate was moist too.  This method seems somewhat opposite of the sponge video and leather craft book.
Also some people say I should not practice stamping on pre dyed what looks like 5- 7 oz leather veg scrap sold in mystery bags at the hobby stores. The pre dyed stuff seems to absorb water and darken when wet and returns to its previous shade though. Yet requires several strikes to make an imprint.
Without seeing the type of leather you are using its hard to completely answer your concerns.   It sounds as though you are latigo leather. Which is a dyed waxy leather that isn't good for tooling and doesn't case.   It's used for harnesses or items that may be exposed to weather or heavy use.  I imagine when you wet it the moisture was trapped against your granite because it doesn't absorb into the grain. Call SpringfieldLeather Co. and get one of their veg tan remnant bags. Then, wet it on both sides either with a quick dip or sponge.... I'm sure you will experience a difference with it.  Good luck!
Most pre-dyed leather isn't veg-tanned (which is the ONLY leather that is suited for stamping or carving & tooling) and from what you are describing you have one of those pieces that ISN'T intended to be stamped or decorated.  It is most important to first learn about the ways leather is tanned and which tanning method results in how each type of leather is used before you go spending ANY money on leather, even scraps, for test/practice purposes.  This basic information is available everywhere and will save your "hide" (little leather joke there) before you make an expensive mistake.
Do yourself a huge favor and start researching leather and how it is tanned and used and you will be a much better craftsman for doing so.  To learn how to work with leather you must read and research everything there is out there, otherwise you are just wasting your time and then wasting others by asking why something doesn't work when you could have known for yourself.  This is a very common thing with new leather workers and you don't want to be in that group.
  • 1 year later...
Great posts and explanations of what its all about, seldom only one correct answer to question, but i think you have all added a lot of good information i can use from now on
Many thanks to you all
Mi omputer is ot ood at speeling , it's not me
