Ambassador pete Posted October 20, 2009 Ambassador Report Posted October 20, 2009 I shoulda framed this guide to tool usage long ago!! TOOLS EXPLAINED! DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh --' SKILL SAW: A portable cutting tool used to make studs too short. PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper. BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to make hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. Son of a b*tch TOOL: (A personal favorite!!) Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need. Hope you found this informative. Quote
Members Tkleather1 Posted October 20, 2009 Members Report Posted October 20, 2009 That is the best explanation of tools that I have ever heard. Fantastic. Tim Worley TK-Leather Quote Tim Worley TK-Leather If you don't ask and dont try how are you gonna learn anything?
Moderator Johanna Posted October 20, 2009 Moderator Report Posted October 20, 2009 Yep, that about covers it. I have to show this to Wade. Johanna Quote You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Moderator bruce johnson Posted October 20, 2009 Moderator Report Posted October 20, 2009 Funniest thing in read in a while. Another to add: 9/16 WRENCH: The size wrench used on arena panel connectors, gate hinges, and stirrup bolt nuts. The one that immediately goes AWOL from every organized open end wrench and socket set I own. Then we could get into chain saws and handyman jacks. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Geo4x4 Posted October 21, 2009 Members Report Posted October 21, 2009 OMG! Everything has suddenly become so clear. Thank You. Quote If its not fun, it's work.
Members Casey Jordan Posted October 21, 2009 Members Report Posted October 21, 2009 Speaking of the S.O.B tool - guess how my kids learned how to cuss! My oldest son still calls the garbage disposal a **$$@#$@**!!! You start out trying to be a good father and teach your kids how to work with their hands and fix things. The next thing you know things have gone all sideways and their cussing,learning how to dodge flying tools, know where the first aid kit is, learn how to dial 911 and know not to tell mom what they learned today. At least they learned something ! Brings a tear to my eye. Quote Casey Jordan www.caseyjordansaddle.com www.artofthecowboymakers.com Q: Do you have A.D.D.? A: Look, there's a chicken
Members simontuntelder Posted October 3, 2013 Members Report Posted October 3, 2013 4 years later and it's still hilarious! Thanks for a good laugh Quote
Members WyomingSlick Posted October 4, 2013 Members Report Posted October 4, 2013 You need to add: metel lathe - useful for turning good solid pieces of metal into brillo pads and/or steel wool. Quote (John 8:32) And ye shall know the truth, and the truth shall make you free. (KJV) And the truth is that religion is nothing more than the lame attempt by largely ignorant people to bring sense and order to a world that was beyond their comprehension. Once you see religion for the delusional and superstitious artifact it is............... you will be free !
raysouth Posted October 4, 2013 Report Posted October 4, 2013 SUPERB !!!!!! Never read a better description. God Bless. Ray Quote
AndyL1 Posted October 4, 2013 Report Posted October 4, 2013 Old thread, but this is so good! HAHA! Andy Quote Blackthorn Leather on Etsy • Blackthorn Leather on Facebook
