Members roo4u Posted January 3, 2011 Members Report Posted January 3, 2011 anybody ever tried the metal clays....gold silver copper bronze and steel are available....i am thinking of using it to make findings for my braiding. Quote TRACY MONSTER FARM SPECIALTIES-custom tack for dog, horse and human
Scary Leatherworks Posted January 3, 2011 Report Posted January 3, 2011 back yard metal casting Check out this guy. Hours of information for the novice metal caster. lots of How-to stuff Quote
mendedbowl Posted January 3, 2011 Report Posted January 3, 2011 did you go to the "naughty bits" section? fun stuff >eyebrow wiggle< Suze their naughty bits section is why i remembered the site Quote
Members amuckart Posted January 5, 2011 Members Report Posted January 5, 2011 Hi Ray, There are two quite different topics here. Pewter is easy to cast and melts at a low temperature requiring little in the way of safety equipment. Brass, bronze etc are very different beasts requiring serious heat and safety kit to do. You can cast pewter in high-temperature RTV, which is the easiest way. The medieval way is to use soapstone, which carves easily and burnishes smooth. You can use plaster of paris, but whatever you use it has to be completely dry. Pewter casts at a temperature that causes water to flash into steam which can blow your mold up, spraying hot metal everywhere. If you use RTV you can sculpt a model and use it to build the mold, if you use soapstone you have to carve the negative, which takes a fair bit of practice. The single most important bit of advice I've heard regarding pewter casting is to make sure your work surface tilts slightly away from you so that if you accidentally dump an entire crucible of metal it doesn't run off into your lap You can melt pewter (britannia metal) on a stovetop, or in a metal ladle with an LPG torch. Safety kit wise a face shield and welding gloves are sufficient, but a good apron is also a good plan. This may be useful: http://chestofbooks....ing-Pewter.html I presume you have Dress Accessories and The Medieval Household? Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Members amuckart Posted January 5, 2011 Members Report Posted January 5, 2011 I've always wondered just how "sturdy" some of that low melt pewter is. I see it a lot at SCA events for sale and it just seems "fragile?" to me. Like it would bend and break easy. Of couse I am pretty hard on my belts.... It worked for medieval people I've had a pewter-buckled belt for about 8 years now, and it's just fine. Of course, it was made from decent britannia metal, not recycled thrift store tankards. Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
AndyL1 Posted January 6, 2011 Report Posted January 6, 2011 I've thought about doing some metal clay work... really only thought about it at this point as it's a whole new set of tools and workspace I'd need to set up, but the results look fantastic! I did find this great site with everything you may need, plus there are forums and YouTube vids on the topic as well: http://www.cooltools.us/ -Andy Quote Blackthorn Leather on Etsy • Blackthorn Leather on Facebook
Members Skald Posted January 6, 2011 Members Report Posted January 6, 2011 Has anyone ever tried casting buckles in lead-free pewter? Apparently it isn't too difficult but I'd like to hear from anyone who has actually done this and hopefully see some of the results. Also brass, bronze and any other metal - pictures would be greatly appreciated especially of the casting process. Ray I've done quite a lot of casting in pewter, brass and silver. The casting itself isn't really rocket science, it's the mould making part that's difficult. For pewter, there are these RTV silicone compunds that you can buy, which are highly recommended. You don't need any particular equipment to get that going, piece of cake - if you just sniff up some basic tutorials to get going. You can of course also make sand castings, but that's a bit more tricky, depending on what you are about to make. Sand castings can't take "negative angles" (naturally), if you do, you'll ruin the mould as you try to remove your model. The detail level isn't really good either, and another downside is that you have to make the mould anew for each casting. The positive aspect is that you can cast almost anything in sand form, an RTV silicone mould can't take much heat, even low melting point metals like pewter will ruin it in the extent. You can probably make a good mould out of limestone too, but that's more or less an artform in itself. Those are the realistic small scale/beginner alternatives. Then there are of course alternatives like plaster moulds, where you use the "lost wax" method (i.e. mould a wax model into the plaster, burn the wax out of it - pour in silver or whatever, and crack the mould open, and there you are). There are also these kinds of rubber compounds, that require pressure and heat (equals expensive equipment). Metals like silver will require either a centrifugal sling or vacuum cabinet (those ain't for free either), otherwise like 9 out of 10 castings will look like sh*t. So anyway, making buckles in pewter and/or brass isn't a big problem, but making a proper mold is more of a problem. For example making the loop for the belt strap in one piece with the buckle to start with, isn't all that easy. You'll have to think "tree dimensional" right from start, otherwise you'll suddenly find out that it must be done in another way, over and over again until you get it right. Such projects are perfect to elaborate over in your bed, when you can't go to sleep. Quote
Contributing Member UKRay Posted January 9, 2011 Author Contributing Member Report Posted January 9, 2011 Hi Ray, There are two quite different topics here. Pewter is easy to cast and melts at a low temperature requiring little in the way of safety equipment. Brass, bronze etc are very different beasts requiring serious heat and safety kit to do. Y This may be useful: http://chestofbooks....ing-Pewter.html I presume you have Dress Accessories and The Medieval Household? I've got the reference books you mention, Al, and appreciate your advice more than you can know - particularly the tilted work surface. What a sensible idea... I do a little silversmithing so have the wherewithall to melt 'hot' metal but have no practical experience of casting metal as yet. It is one of those 'projects' that I've been meaning to do for ages but never got around to. This year I'm going to give it a try. The soapstone mould idea sounds like a good one, but the 'synthetic material' moulds look a whole lot easier! Lots of food for thought. Thanks. Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members MikeCahill Posted January 26, 2011 Members Report Posted January 26, 2011 I've got the reference books you mention, Al, and appreciate your advice more than you can know - particularly the tilted work surface. What a sensible idea... I do a little silversmithing so have the wherewithall to melt 'hot' metal but have no practical experience of casting metal as yet. It is one of those 'projects' that I've been meaning to do for ages but never got around to. This year I'm going to give it a try. The soapstone mould idea sounds like a good one, but the 'synthetic material' moulds look a whole lot easier! Lots of food for thought. Thanks. Ray Hi ray, just remember, your mold must be bone dry before you pour molten metal into it, or you'll have hot metal flying in all directions, a friend makes badges out of old battered "pewter" beer tankards that he buys off car boot sales they look quite impressive cheers Mike Quote
Contributing Member UKRay Posted January 26, 2011 Author Contributing Member Report Posted January 26, 2011 Hi ray, just remember, your mold must be bone dry before you pour molten metal into it, or you'll have hot metal flying in all directions, a friend makes badges out of old battered "pewter" beer tankards that he buys off car boot sales they look quite impressivecheers Mike Thanks, Mike. I'm ahead of you here as I have gathered a motley collection of old and battered pewter tankards that are destined to turn into buckles sometime very soon. I also experienced 'flying metal' whilst pouring lead into a 'not quite dry' baking tin to make a punching block... a very impressive spatter of liquid lead almost put me off any more experimentation! LOL Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
