Members Houlihan Posted October 19, 2011 Members Report Posted October 19, 2011 I usually use one coat of NeatLac but I make sure I get it thoroughly coated. For oil I use EVOO. Bobby Bob your work is amazing. What is the best replacment for Neatlac, or is there one. I cant find Neatlac anywhere. Thank you for posting your work inspires me to try harder. Wes Quote
Contributing Member Ferg Posted October 20, 2011 Contributing Member Report Posted October 20, 2011 Clear Lac ferg Bob your work is amazing. What is the best replacment for Neatlac, or is there one. I cant find Neatlac anywhere. Thank you for posting your work inspires me to try harder. Wes Quote
hidepounder Posted October 20, 2011 Author Report Posted October 20, 2011 Bob your work is amazing. What is the best replacment for Neatlac, or is there one. I cant find Neatlac anywhere. Thank you for posting your work inspires me to try harder. Wes Wes, you can buy it through Panhandle Leather....it's called Clear Lac which is the manufacturer's own label. I believe Springfield Leather carries that label also. Or you can contact Sheridan Leather Outfitters. They carry it under their own label which is Wyo-Shene. Bobby Quote
Buttons Posted October 21, 2011 Report Posted October 21, 2011 I usually use one coat of NeatLac but I make sure I get it thoroughly coated. For oil I use EVOO. Bobby Bobby What is your technique for applying/removing the paste? I get a lot in the background areas and in removing it I also clean out the pear shaded areas. Thanks Ralph Quote
Buttons Posted October 21, 2011 Report Posted October 21, 2011 do you cut the lining after its all assembled? Quote
hidepounder Posted October 22, 2011 Author Report Posted October 22, 2011 Bobby What is your technique for applying/removing the paste? I get a lot in the background areas and in removing it I also clean out the pear shaded areas. Thanks Ralph I apply the paste, full strength, with a piece of trimmed wool skin. I use them to remove the paste also. I rub the paste in thoroughly and then continue wiping it off with the wool skin until no more residue appears on the wool skin. If you want more darkening in the depressed portions of the tooling, try wrapping paper towels around a flat stick like a paint stir stick to remove the paste. This will leave paste in the depressed areas which you can allow to set a little longer before removing. When you begin removing the rest of the paste take care to only wipe as deep as you need to. You might also want to try thinning the paste with Tan Kote or mineral spirits to get a thinner consistency when applying. Hope this helps.... Bobby Quote
hidepounder Posted October 22, 2011 Author Report Posted October 22, 2011 do you cut the lining after its all assembled? Yes, I do all my finger cutting after the lining is glued, sewn and the edges are burnished. Quote
