Try using a Sheridan beveler instead of the crafttool ones, the angle is steeper, Also fill the "hole" in using a USMC Black instead of the common black. It looks as you are using the sprit dyes instead of oil dyes. Myself I prefer the latter.
The problem is that you are trying to use the wrong image. That image is of a bullet hole that has gone through a piece of sheet metal that has both a final coating and a primer coating. The square like frame around the hole is designed to look like the primer, . . .
Typically, . . . that is the image of a bullet hole in a car body.
Enclosed is a 240 grain, jacketed hollow point, +/- 700 feet per second, .45 caliber, at about 8 feet, . . . going through a 9 oz piece of veggie tan. The quarter is to help you determine the relative size.
May God bless,
Dwight
www.dwightsgunleather.com
I have never tried this buy you might try using an undercut beveler to make it look more like the edges are rolled back. by the bullet.
Leather workers, Here is a photo of what I'm working on. I need this to look like a bullet hole and it will be in black leather. I got the image off of the internet but when tooled it looks like a odd flower. I need depth where the bullet goes through and any suggestions otherwise I'd appreciate. Thanks a bunch!
Gotta love this forum !!! :grouphug5vj5:
Only here would someone go and shoot a bit of leather for someone else to see what it really looks like !
Gave me a good chuckle
thanks guys
Insanity is hereditory, you get it from your kids
  • 3 months later...
:You_Rock_Emoticon:
Seriously, guys, don't waste a time on carving these holes.
Bring your masterpieces to Mr. Dwight to let him make his nice decorative shots!
And remember leather must be properly cased to help Mr. Dwight do great, deep and crisp holes :clapping:
Sorry for flood but I also gotta love this forum for such a great guys here!:grouphug5vj5:
If you can't have a hole completely through the item, take something like the handle used for 3-D stamps, or whatever caliber you want, and use that to do the hole. Then bevel down to the depth of the flattened area in a smooth radius, rough edged, or whatever look you want to portray.. Where I see a problem is getting it to stand out as a hole, and not just a decorative design. Like Dwight showed, a real bullet hole has a darker ring which is caused by lead ,or bullet lube, rubbing off onto the item shot. As the bullet pierces the item it curves in before opening up. On soft targets like paper, or leather the sides will spring back after the bullet passes through. That is for standard shaped bullets. Wadcutters, bullets that have a flat nose, and are used in target shooting, will actually punch a hole like a hole punch. To get this to show up as a bullet hole I feel that you will need to highlight it in some fashion.
You laugh at me because I am different. I laugh at you because you are all the same.
thanks guys
Ha ha ha... I completely agree. Awesome job Dwight. If that darned leather isn't cooperating.... Shoot it! LOL
A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
If you are imitating the look of a hole through black painted metal, like your bike fender, the hole is a shadow and won't be as "black" as the black paint. If there is light on the other side, then it will be a bright spot.
