Moderator Wizcrafts Posted June 11, 2018 Moderator Report Posted June 11, 2018 2 hours ago, OLDNSLOW said: I am running a 441 clone with an oil pot and using silicone oil in the pot, yet the same type of issues still occur, and If my recollection serves me right I did a search for titanium needles sometime in the past when the same issue presented itself. Wiz if you know of a dealer who has the needles in 25 for 277 thread please let us know so that they can be look at for price comparisons. I have a recent post up that is asking the same type of question with a little different twist to it. In fact one the most interesting things that I have happening is that when I am sewing 2 layers of 9 oz wicket and craig leather I will actually have some squeaking going on as the needle is going through the leather, this is after it has been glued together using Barges glue after it has dried for at least a day in warm to hot days or put on a forced air boot drier when the ambient temps are low. It is the weirdest thing to hear and watch. I have gone in and made sure that everything is clean, well oiled and running like it should be a far as I can tell. Can you look at you needle package and tell me what point it shows? It could be P, S, D, etc. Also, are you already using a #25/200 needle? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members OLDNSLOW Posted June 11, 2018 Members Report Posted June 11, 2018 Wiz I am running a 25/200 S Schmetz needle. Thanks Quote
Moderator Wizcrafts Posted June 11, 2018 Moderator Report Posted June 11, 2018 I encountered a job where the S point gave me fits. I switched to a diamond/triangle point and it did the job without any more issues. The diamond point lets the thread sit on top, rather than getting drawn in on the ends. It gives a more pronounced effect. Bob sells them. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members DrmCa Posted June 11, 2018 Members Report Posted June 11, 2018 I think that Wiz's original guess that the smaller needle is the culprit is correct. The larger needle has more space to "hide" the thread in, and overall creates a larger hole, so trying a larger needle may actually work. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members OLDNSLOW Posted June 11, 2018 Members Report Posted June 11, 2018 I might be wrong but I think the 25 is the correct size if not a little big for 277 thread, I was doing a job just a few days before this last job to discover that I had a 24 needle in the machine and you talk about a real nightmare. I thought it fixed all my problems when I went to the 25, but it didn't so I am not sure if the type needle that wiz recommends will cure it but I am going to try it. Thanks for the input wiz I will give a Bob a call as I have a few extra bucks to spare and give those whirl, not a curly wurly, just a whirl. Quote
Members OLDNSLOW Posted June 11, 2018 Members Report Posted June 11, 2018 Wiz I made a call and need a little more clarification from you, is the diamond point or the triangle point that you used to cure the problem? Thanks for the help!! Quote
Moderator Wizcrafts Posted June 12, 2018 Moderator Report Posted June 12, 2018 3 hours ago, OLDNSLOW said: Wiz I made a call and need a little more clarification from you, is the diamond point or the triangle point that you used to cure the problem? Thanks for the help!! The package I got from Bob says "Dia" - which means diamond. The actual geometry is triangular. It has three sides that converge to a sharp point. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Big Sioux Saddlery Posted June 12, 2018 Members Report Posted June 12, 2018 Part of the squeak and needle sticking problem is Wickett and Craig's leather. I use both Wickett & Craig and Hermann Oak in the shop, and time and time again, I've had this happen with the W & C when I haven't changed a thing on the machine. Quote
Members Sonydaze Posted June 12, 2018 Members Report Posted June 12, 2018 I keep a small piece of bee's wax on the machine and rub it on the needle shaft when things start lifting (usually glue not completely cured) This helps and also seems to polish the needle so it slides out easier. Quote http://www.bound2please.com Sewing machines: 3 - Sunstar 590BL, Artisan Toro 3200, Juki LK-1900HS, Juki DDL-8500-7, Juki DDL-5550N, Pfaff 138-6/21, Pfaff 546-H3, Pfaff 335-H3, Adler 221-76, Singer 144WVS33, Singer 29K-51, Siruba 747B
