Andrew,
According a few of the old guys, pricking wheels were the tool designed for marking out stitch spacing. They make a more distinctive mark to be felt than an overstitcher does. The oversticher came along after the stitching to even out any slightly off stitches and to help "set" the stitches. That meant a person needed to have a set of both. Some enterprising soul decided that you could mark out the spacing withan overstitcher and not need a pricking wheel. Most of my pricking wheels go to other countries where a lot of handstitching is still done. Some say they use both, but seems like most use pricking wheels for layout. Back in the day CS OSborne made overstitchers with narrow wheels and wide wheels. The wider wheel ones do a nice job on backside stitches because they will lay the puckering down a little more and set bigger thread. The narrower ones will open that thread line on the back a little more if the thread pulls in, which sounds like what Nick is dealing with.
Bruce Johnson
Malachi 4:2
Andrew,
Yes, The thread is cutting a line going with the tight stitch line, but I am willing to sacrifice the back to get the nice front stitch on belts. When I sew holsters I don't use a stitch near as tight and can get a much better looking back side stitch. I thought I should be adjusting the bottom bobbin tension to compensate, but I Bob told me that was the price of the tight stitch on this kind of machine.
Here an example of what I am talking about with using an overstitcher to clena up the bottom stitch. This is a billet strap for a brief case. One scan shows the top stitches. The other scan shows the bottom stitchlines with one side overstitched and the other as it came out of the machine.
Bruce Johnson
Malachi 4:2
  • 10 years later...
On 12/16/2011 at 11:23 AM, bruce johnson said:
Andrew,
Are you talking about using a wheel for machines?
No, I am talking about using an overstitch wheel on the bottom side of the stitching after machine sewing. This will dress the stitches and make them look more like the top stitches.
Bruce Johnson
Malachi 4:2
Thanks for sharing that @bruce johnson I have had one of these for like 30 years and had not realised that potential. Only does a bit over 1/8" but with a bit of luck I will be able to get one with a bit wider spacing. Now I will have to look to set my stitch length to near perfectly match the overstitch wheel but for some jobs it should be well worth the effort.
YouTube Channel
Instagram
overstitcher.... you learn something new everyday. That really is interesting. Will check them out... Thanks a lot for that hint.
Thanks, that’s what I meant. Going to have to try it. Hopefully it wont cut the thread at all, my wheel looks a bit sharp.
