What Is The Way To Store Leather Hides And Leftover Leather?
  • 2 years later...
On 7/10/2014 at 8:16 AM, JLSleather said:
Chrome leathers are hung over large dowels (think 7' wide towel rack with 5 'levels') suspended from the ceiling. Lets me pick the weight and color I want easily.
Sorry to resurrect an old thread, but I just moved into a new house, and I finally have a room all to myself to make into a studio. I'm trying to brainstorm ideas for how to hang my leather hides so that I can easily see them all (just the pre-dyed ones, not the natural veg-tan; I don't really need to see that all the time & will probably leave it rolled the way it came). I have some chrome-tanned, as well as some pre-dyed veg-tan double shoulders. Most are 5-oz or lighter weight.
I have limited space, as the room is not very large (it used to be a kid's bedroom). I like JLSleather's idea of hanging them over large dowels. I did something similar in my old studio in the closet (but the closet in the new place is too small for that). I might be able to hang them from the ceiling -- but how do I know if the ceiling will support the weight? If not that, I will have to have the husband help me build some kind of rig -- but it's got to be compact so it doesn't overwhelm the room.
If anyone has more ideas for how to maximize a small space and display my hides for easy use, I'd love to hear them! Thanks in advance.
Just dont leave a nice piece of italian calf leather rolled up on your work wench where you were previously dying something.......... Im sure those little stains will just add to the charm of the finished item :-(
I don't have a pic of it, now we've moved and don't have a "shop".  You can make a rack -- like I did --- with a couple of 10' long 1x4, which are about $3 each.
Cut them each in 3 pieces, about 4.5', 1.5', and 4'.  Cut 'vee' notches in teh short pieces, something like this...
Then line 'em' up, drive a couple of screws in the top ends, tying the three pieces together.
Untitled-2.jpgDo the same with the other 1x4, so you have two the same, and place dowels (closet rods) in the vees, and hang your leather over the dowels.  You'll have three rows as wide as the dowels (usually about 6-7 feet), high enough that the leather wont drag the floor when draped over the rods, and offset so you can see what is on each "rack" from the front. :dunno:
You could 'tie' em together with one more across the back, but prolly not needed.  Total investment, $10 and 30 minutes.
5 leather patterns
Being floor space is a premium in this case and your not sure about your ceiling, your husband can always get a stud finder at Lowes or Home Depot and then find the cross beams in the ceiling, those more familiar might correct but the cross beams are usually of 6 inch centers, he could sink some very long eye bolts into the ceiling so that you could hang things.  There would be any great cost involved and it would help keep your floor space open.
Ceiling joists are normally 16" on center, but best to confirm by drilling a 1/16" hole where you think the joist is located.  Drill a couple of holes side by side to find the center of the joist, then you can secure your heavy screws into the center.  You can easily patch the tiny holes with a dab of mud.
Cowboy 4500, Consew 206RB-4
When I buy a side or double shoulder, . . . it stays rolled up until I need it.  Stands on end in the bottom of my leather vault.
It's basically a box, . . . 4 x 8 sheets of particle board make the front and back, . . . 2 x 12's make the sides and tops.
I put some 1/2 inch conduit along one wall, . . . bent some re-rod into "ell" shaped pieces, . . . attached 1 x 2's to the re-rod, . . . put nails in the 1 x 2's, . . . punch small holes in the leather and hang it inside the vault.
In the drawing there is just one "ell" and one hide hanging, . . . but I've got several and the ell's swing out so I can see what is hung in the one behind it.
Not bragging, . . . but this is one of the best Ideas I've had in a long time, . . . works really great, . . . could be scaled down smaller or thinner, . . . depending on the needs of a person.  I could see one made of 2 x 4's standing behind a bedroom door.
All my pieces that will go into a 16 by 30 storage tote, . . . goes in there.  If they are too big for the tote, . . . they stay in the vault till they get cut down.
May God bless,
Dwight
www.dwightsgunleather.com
  • 2 weeks later...
