Members Hoyt64 Posted February 6, 2012 Members Report Posted February 6, 2012 Hello, I am just getting started in leatherwork and I am making a knife sheath for my first project. I have punched the holes and handstitched the leather for the belt loop and it turned out well. My question is , what is the best way to punch the holes down the side of the sheath since it has a thick welt that will be between the 2 pieces of folded over leather to be stitched together. I have a punch that has 4 prongs on it but I don't think it is long enough to get all the way through the 2 pieces of leather and the welt. Any advice would be appreciated. Quote
Phatdaddy Posted February 6, 2012 Report Posted February 6, 2012 Hello, I am just getting started in leatherwork and I am making a knife sheath for my first project. I have punched the holes and handstitched the leather for the belt loop and it turned out well. My question is , what is the best way to punch the holes down the side of the sheath since it has a thick welt that will be between the 2 pieces of folded over leather to be stitched together. I have a punch that has 4 prongs on it but I don't think it is long enough to get all the way through the 2 pieces of leather and the welt. Any advice would be appreciated. You'll have to use an awl. Most here will recommend a spade or diamond bladed awl, however I use a round one as it's the only one I have at present and it works. Others use a drill press or dremel to drill holes, for the most part I think that is discouraged. Just make sure your awl is very sharp and polished. Good Luck, Kevin Quote
KAYAK45 Posted February 6, 2012 Report Posted February 6, 2012 A drill press or a drill with the smallest bit works nicely! Use a stitch wheel to get the distance you want. Quote Once believed in GOD and the DOllAR...... Hello God!
Members ChuckBurrows Posted February 6, 2012 Members Report Posted February 6, 2012 http://www.wrtcleather.com/1-ckd/tutorials/_leatherstitch.html Quote Wild Rose Trading Company Two roads diverged in a wood, and I, I took the one less traveled by, And that has made all the difference.
electrathon Posted February 6, 2012 Report Posted February 6, 2012 For thick multi-layer pieces like this I use my drill press (to keep it straight) and for a bit I use a large sewing machine needle. Tandy sells 3 sizes of large needles, I use the middle size most of the time, depending on the thread I am using. Aaron Quote
terrymac Posted February 7, 2012 Report Posted February 7, 2012 (edited) Take the awl chuck out of the wooden handle and use in a drill press as Aaron suggests. You get the best of two worlds, straight holes and being punched with a diamond awl at the proper angle. Terry Edited February 7, 2012 by terrymac Quote
Members cowdog128 Posted February 7, 2012 Members Report Posted February 7, 2012 A old saddle builder showed me the best way [ for me anyway] a dremel with a very small bit i use a stitch wheel or old fork [shout out twinoaks lol] to mark my holes and zip zip in no time you have perfect holes hope this helps. Happy trails Quote
Members Hoyt64 Posted February 7, 2012 Author Members Report Posted February 7, 2012 Thanks for the replies and advice, I will give it a try this weekend. Quote
Members steelhawk Posted February 13, 2012 Members Report Posted February 13, 2012 I used a drill press for mine, but I turned the 1/16 bit upside down and pointed it with a grinding stone. I chuck it, turn the drill press on and drill the holes. With the bit upside down, it doesn't remove any leather. Quote www.bearriverholsters.com
Members Hoyt64 Posted February 13, 2012 Author Members Report Posted February 13, 2012 Well, I marked the holes and used my drill press, the holes came out good, and the stitching turned out good as well. Next time I will try the bit turned upside down and sharpened method. I used the 2 needle method of stitching and my only problem was every once in a while I would stab the thread while pushing the 2nd needle through the hole. From what I read this happens somewhat often. I ordered some egg eye harness needles with a blunt tip and hopefully that will help some. Thanks again for the advice, I am looking forward to working on my next knife sheath . Quote
Members 556guy Posted February 13, 2012 Members Report Posted February 13, 2012 I used the 2 needle method of stitching and my only problem was every once in a while I would stab the thread while pushing the 2nd needle through the hole. From what I read this happens somewhat often. I ordered some egg eye harness needles with a blunt tip and hopefully that will help some. Thanks again for the advice, I am looking forward to working on my next knife sheath . When you have the second needle halfway thru, pull the first thread back a little. If you've stuck the thread it will show up and it can be corrected easily. Quote
Members Suicide Posted February 13, 2012 Members Report Posted February 13, 2012 (edited) When you have the second needle halfway thru, pull the first thread back a little. If you've stuck the thread it will show up and it can be corrected easily. Or even easier - one needle half way in, second needle half way in, then use both threads to push needles a bit futher, then pickup each needle on the other side. no chance to stuck thread. Edited February 13, 2012 by Suicide Quote My leatherwork gallery
