Hi monkfinck. Have you checked the needle bar height? If you need a new shuttle hook, or race assembly one of us sewing machine dealers can get it for you. Let me know. Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
Chris,
I'll have to agree w/Anne Bonny,I just checked the hook ring from our Cowboy 2500 in a 45K25 & it looks like it might fit with alittle grinding were the pins mount.
Let me know if your still need one.
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I reversed the retainer ring, tried adding thinner shims, raised and lowered the needle bar dozens of times, tried different sized needles.
When I hand crank the wheel everything appears fine - the hook finds the loop and completes the lock stitch. When I start sewing leather it stitches ok on a straight pass, but when I drop the needle and turn 90 degrees then commence stitching, after two or so stitches... a skipped stitch.
I think the 45K is tired. I know I am tired! My business depends on a reliable machine, so after doing my homework, I called Steve Tayrien and purchased a Cobra Class 4 package w/ the accessories. http://www.leathermachineco.com/catalog.php?item=57
As most of you already know, Steve is extremely helpful and passionate about his Cobra machines. Initially, I was tempted to go for an Adler 205, but numerous sources told me Adler is now making this machine in China and I could not personally justify paying double the money vs. the Cobra (Juki 441 clone). Juki parts are also reasonably priced in comparison to Adler.
The Cobra should be delivered late next week. Thanks to everyone who tried to help me resuscitate my 45K. I still love my other vintage machines, but I am curious to see how a brand new machine handles in my shop.
---Chris
  • 5 years later...
if anyone is still interested in replacing the shuttle ring in a singer 45K i just replaced the hook/shuttle ring in a 45k-25 part number 91430 with a shuttle ring out of a Typical TW3-441 part number: 52WF1-032, drop in replacement, no grinding or modification required only difference is the original singer shuttle ring is 3.30mm thick the typical one is 3.50mm thick.FullSizeRender.jpg.4e354e7816de239490b6b3ac1b9d7f8e.jpg
Edited by gecko nz
I have no need for a replacement but this is a good hint! :spoton:I always wondered if parts from new machines could fit the old Singer 45K and Adler Class 4 & 5. At least worth checking it out when someone is in need of replacement parts. I´m sure a lot more parts will fit but for sure depends on the machine.
Edited by Constabulary
Great bit of info to keep the old Singers working, and not turning into doorstops, or lampstands (worse upcycle seen on ebay, ever).
“Equality?   Political correctness gone mad, I tell you, gone mad!!!!    Next they'll be wanting the vote!!!!! :crazy:“.
Anger and intolerance are the enemy of correct understanding
Worse is "tractors" :((
"Don't you know that women are the only works of Art" .. ( Don Henley and "some French painter in a field" )
parts from the typical tw1-2b can be used on a 132k6, feed dog, needle plate, main tension assembly, needle bar, the same needle bar with clamp will also fit an adler 105-64 at a fraction of the adler price.
  • 8 months later...
 those people who choose  to turn these old sewing machines into art have one thing good out of it.they have acsess.to absolute parts
