Members Iron Pounder Posted August 5, 2012 Members Report Posted August 5, 2012 I have a wallet that I'm trying to do that the pockets will be very close to each other and I need to glue them to hold until I get it stitched. Trouble is I only have 3/16" of an inch and when I glue it up it closes the pocket too much. This is cow embossed to look like gator so it is not smooth. I've not used any tape before but wondering if a very strong sewing tape would work. Any advice would be great. Quote
Ambassador pete Posted August 5, 2012 Ambassador Report Posted August 5, 2012 I have a wallet that I'm trying to do that the pockets will be very close to each other and I need to glue them to hold until I get it stitched. Trouble is I only have 3/16" of an inch and when I glue it up it closes the pocket too much. This is cow embossed to look like gator so it is not smooth. I've not used any tape before but wondering if a very strong sewing tape would work. Any advice would be great. put scotch tape along the edge to block the "un-glued" part. Use contact cemet on both pieces- dry and remove tape. pete Quote
Members Iron Pounder Posted August 5, 2012 Author Members Report Posted August 5, 2012 Pete, that's a great idea and I will try it right now but wondering if the glue will bleed over some when I push the two parts together. Maybe I just put too much glue on. I will try and put less on than I normally do and use the tape. Quote
Ambassador pete Posted August 5, 2012 Ambassador Report Posted August 5, 2012 Pete, that's a great idea and I will try it right now but wondering if the glue will bleed over some when I push the two parts together. Maybe I just put too much glue on. I will try and put less on than I normally do and use the tape. It won't bleed if you use contact cement and let it dry. Smear it on with your finger tip for such a narrow piece. That small a section and it should be dry in less than a minute. Check it to see if it is tacky or better yet, dry feeling. Quote
Members Anacott Steel Posted August 6, 2012 Members Report Posted August 6, 2012 FWIW iron pounder I dip the non pointy end of a toothpick into glue and place a few spots to hold the pockets together before stitching. Quote
Members Kevin Posted August 6, 2012 Members Report Posted August 6, 2012 I use Q-tip type things that are made for applying make-up. One end is shaped like a Q-tip and the other is pointed. It is denser than a Q-tip and doesn't turn into mush immediately. I don't know about tape, I'm afraid it will take something off the leather or leave something on the leather, but people do seem to use it. You might try thinning your glue, something like that, I would use two coats of thin glue. Good luck, Kevin Quote
Members The Grizzly Posted March 31, 2013 Members Report Posted March 31, 2013 Those of you who use DAP WeldWood, what do you thin it with? Quote Craig Collier ~Grizzly Custom Knives~
stelmackr Posted March 31, 2013 Report Posted March 31, 2013 (edited) ... I've not used any tape before but wondering if a very strong sewing tape would work. Any advice would be great. I use this all the time: http://www.wawak.com...e-1-4-x-60-yds/ Got the idea from Wiz Bob Stelmack www.pslac.org Edited March 31, 2013 by stelmackr Quote Bob Stelmack Desert Leathercraft LLC Former Editor of the, RawHide Gazette, for the Puget Sound Leather Artisans Co-Op, 25 years of doing it was enough...
Members Dwight Posted March 31, 2013 Members Report Posted March 31, 2013 I regularly glue up very narrow areas. I use plumber's acid brushes purchased from Harbor Freight, . . . http://www.amazon.com/Harbor-Freight-Horsehair-Bristle-Brushes/dp/B006ZBD95Q I use straight Weldwood. Just take your time, . . . it'll work out. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
cardinal leather Posted April 1, 2013 Report Posted April 1, 2013 I use cheap craft paint brushes for weldwood or laminate type glues. About a # 2 I cut the end square with my serrated scissors so it holds the bristles . this gives me a glue line about 1/8 - 3/16, as mentioned above take your time it will work out. don't throw the brush away. It will get hard when it drys, however it will turn soft again when you use it again. just flatten the tip and let it dry. Brush last a long time. Quote
Members humperdingle Posted April 1, 2013 Members Report Posted April 1, 2013 Call me a skinflint, but I use tiny offcut pieces of veg tan leather as glue spreaders Quote
Members circlet Posted April 4, 2013 Members Report Posted April 4, 2013 This is what I found works very well for wallet interiors. http://springfieldleather.com/25969/Tape%2CSeamstick-Basting%2C1-4%22/ Quote
Members mikesmith648 Posted April 4, 2013 Members Report Posted April 4, 2013 I go to the sewng store like JoAnn's and get the seam tape. It comes in different widths and will hold really well while you sew...........and won't ooze out on the edges. Got the hint from Kevin King who happens to make a LOT of wallets Quote Emergency Room Nurse by profession.......Leatherworker at heart!! Hoping to reverse the order in that one of these days!!
Members oltoot Posted April 4, 2013 Members Report Posted April 4, 2013 I have successfully used masking tape and painters tape Quote
Moderator Art Posted April 4, 2013 Moderator Report Posted April 4, 2013 If you want to use contact cement, thin it out a lot so it is easier to control. Place it in a very thin line (use Q-Tip if necessary), and wait till it dries. Put on another coat if not shiny when dry. Or cheat and use Seamstick tape, it works just fine. Get Seamstick at Rochford Supply, or ask Kevin, he may carry it (you'd be suprised what he has at Springfield). I find it hard (impossible for me) to get a zipper in straight without it. Art Quote For heaven's sakes pilgrim, make yourself a strop!
Members The Grizzly Posted April 6, 2013 Members Report Posted April 6, 2013 Can you thin contact cement with Xylene? Quote Craig Collier ~Grizzly Custom Knives~
