Members Dogface Posted November 3, 2012 Members Report Posted November 3, 2012 I have just finished setting up my airbrush system but have not used it yet. Seems that one must protect yourself from the aerosolized particles of dye or other substance you are airbrushing. Do you use a simple surgical mask or full respirator? After you're done how do you clear the room before you remove the mask ? Even with fans and open windows I dunno how long it takes to make the room safe. Thanks in advance Mark Quote
RMB Custom Leather Posted November 3, 2012 Report Posted November 3, 2012 Good question I have been wondering that myself, which mask is the best. Quote
Ambassador Beaverslayer Posted November 3, 2012 Ambassador Report Posted November 3, 2012 What, your supposed to wear a mask??? No, just kidding....It all depends on the type of product you will be spraying. Home Depot sells a good respirator that should cover pretty much anything that a leather worker is going to use, get the one that has replaceable filters, so when they clog up, you can change them without having to buy the mask all over again. Those filmsy dust masks will work also, but only if your spraying for a very short time. Quote
Moderator Art Posted November 3, 2012 Moderator Report Posted November 3, 2012 For Acrylic paint I don't use anything with an airbrush spraying at 20 lbs with a .20 or .30 nozzle as there is little overspray. For spirit dye I use an organic VOC mask with replacable cans. Anything else I use the VOC mask. Art Quote
Contributing Member TwinOaks Posted November 3, 2012 Contributing Member Report Posted November 3, 2012 I'm with Beaverslayer....Breath Deeply! I have moved my spraying rig so I can use it outdoors. It's a few steps from my table to fresh air, so I just step outside for the spraying. Quote
Moderator immiketoo Posted November 26, 2012 Moderator Report Posted November 26, 2012 I bought the respirator mask at the hardware store thats rated for vapors, not the particle version. However, I also created a cheap hood by using a clear plastic tote and my shop vac. Cut a hole big enough for your vac hose in the side of the tote, cut down a furnace filter to fit inside of the tote and put it against the vac hose. Turn on the van and voila! Instant spray hood. I don't use my respirator for spraying because I cant smell any of the vapors. I do use it when I glue with barge though. Quote
Members oldtimer Posted November 26, 2012 Members Report Posted November 26, 2012 I built a spraybox out of plywood with a kitchen fan on top and a vent.hose out through the wall Quote
Members benlilly1 Posted November 26, 2012 Members Report Posted November 26, 2012 I use a respirator mask and a fan in a window. Clears out pretty fast with a fan. I sprayed cabinetry for 25 years and you better wear a respirator to be safe. Quote
KAYAK45 Posted November 27, 2012 Report Posted November 27, 2012 If you want to build a small "Paint Booth" or "Glue Booth" be advised almost all fumes are heavier than air and a bottom collection system, vented outdoors will be the best. How do I know this? Check the OSHA fines I paid for a top vent paint FUME RECOVERY system that cost thousands and was ruled INOP by our Federally friends. Really, it was proven to me that the fumes are heavy and can collect in low areas of a shop. This is not only a BREATHING problem, but a potential SPARK problem around flame (furnace/water heater?) as well as ELECTRICAL SPARK (air compressor on floor?). Kevin Good luck all. ! Quote
