  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Hi OWLSHD, and welcome to the forum! For contact cement I use Weldwood contact cement with the red label. Once it sets I usually need a knife to separate the layers. You can get it at about any big box hardware store.
Bob
There are always possibilities....
Bob Blea
C and B Leathercrafts
Fort Collins, CO
Visit my shop at http://www.etsy.com/shop/CandBLeather?ref=si_shop
Instagram @bobbleacandbleather
Master. White can, get the thinner too.
Art
Titan DX Premium contact cement. Water base, no smell and it works great. I ran across this stuff when I was rebuilding a 100 year old pool table. I used it on all the vener work. Then I took it inside and used it on my leather work. This stuff sticks as well as anything I have used.
Ditto what Art said. Been using masters for a year now. I like it better than barge.
Thank you to all that have replied. It is very expensive trying products that may or may not work, so I appreciate hearing of success through long term use.
I've given Weldwood a shot a few times. Maybe I did not allow for enough dry time but the tack I got was really bad.
I use the stuff from Tandy with their thinner, mainly because it works and I can buy it locally. Do feel that there are better options out there though. for the first 6 mo's I used nothing but Titebond wood glue. Problem with it is it needs pressure and time to set up. Now that I do belts that isn't so practical.
What thinner on the weldwood?
The can says to clean up with Xylene so I presume that is the solvent base. I haven't tried thinning it though and the can does not mention thinning.
