Members the gafer Posted January 1, 2013 Members Report Posted January 1, 2013 Hi all I have put some press studs/snaps on a pouch I have made the leather is 3mm veg tan but I have had to skive and thin the leather for them to fit and it looks sloppy the shaft just dunt go all the way through can anyone tell me what size I would be needing the caps are 12mm but shaft are tiney this is my 1st time using them so any help would be grate and taken on board many thanks kev Quote
Moderator immiketoo Posted January 1, 2013 Moderator Report Posted January 1, 2013 Kev, without pictures its gonna be hard to tell you anything of value. Quote
Members the gafer Posted January 3, 2013 Author Members Report Posted January 3, 2013 I carnt post pics on my touch pad my lap top won't load this site for some reason Quote
Members brands01 Posted January 15, 2013 Members Report Posted January 15, 2013 It sounds like uou are using a Line 20 snap, which is too small for that weight of leather. You need a line 24 whic will have a longer shaft and a larger cap. Quote
Members Matt S Posted January 15, 2013 Members Report Posted January 15, 2013 Are you skiving the entire thickness of the leather, or just around the hole where you are fixing the stud? Also, where are you getting your studs? Quote
Tree Reaper Posted January 15, 2013 Report Posted January 15, 2013 I have put some press studs/snaps You have to be specific as to what you are using. Quote
Members the gafer Posted January 16, 2013 Author Members Report Posted January 16, 2013 Round the hole is where I skived buddy I am using the wrong size with the looks of things I got a set off ebay Tree reaper the msg you sent me I deleated by mestake pal and only saw it as I pressed de leat so could you send me a pm mate Quote
