I use my wifes old hose stockings to filter it into a dropper bottle
Yup. That was the direction I was headed - though I'm single so I had to buy some stockings myself...
1. I stumbled across these storage bottles at HF ( http://www.harborfreight.com/pack-of-3-8-oz-storage-bottles-with-twist-caps.html )
2. Grabbed some cheap pantyhose at a dollar store
3. Mixed resolene and distilled h2o in a bottle
4. Added the fabric while screwing on the cap like this guy does with regular paint bottles
5. Filled the airbrush from the filtered bottle
I ran about an ounce through the brush without any clogs.
  • Replies 77
  • Created
  • Last Reply
Top Posters In This Topic
I saw the same video awhile back. I have no idea what people did w/o youtube or web sites like leatherworker.net.
Many thanks for the tips.
  • 2 months later...
I purchased the HF brush, it came as a kit. I was using resolene cut 50%- 50% with H2O. I didn't have any problem spraying it. I didn't clean it the right way, when I tried to use it again, it was clogged. I put the tips in windex and soaked them, then it was fine. I read another post that said you are better off putting the finishes on by hand. I only spray the dyes, it is to much of a hasel cleaning it after using any of the finishes.
Jim
well, using an airbrush (AB) requires cleaning after using. Since my first post I have upgraded my AB. I dumped the VEDA, it wouldn't spray anything without spitting, and I tore it apart and thoroughly cleaned it, still no luck. So after watching ebay and reading alot of posts on AB forums I bought an Iwata eclipse side feed and a badger Spirit, also a side feed. What a huge difference especially when doing fine detail! I still use the Master AB but mainly for finishes, it does fine for that with a .5 needle. The Badger is a .3 and the Iwata is .3 also. Both spray dyes and thinned acrylics great. I did have an issue with Angelus silver metallic and switched to a createx pearl acrylic, when I have time to test it I'll post info here.The pearl's are suppose to be ground finer, hopefully they will work. The main thing I have learned from using an AB is it takes practice, practice and more practice. When spraying dyes vs a dauber, I can control the lighter color darkness much better than with a dauber, and painting flower leaves etc takes practice but can be done. I have found that when spraying dyes, to clean the leather with alcohol before spraying also helps the dye (fiebings alcohol based) absorb more evenly.
Edited by retiredff
Some of the spitting could be water getting in the air line, too. If you don't already have one, get a moisture trap for the air line.
5 leather patterns
I have one, thanks.
  • 3 months later...
I see everyone talking about dyes, paints, finishes and acrylics. I'm sorry if I missed it but I didn't see anyone mention stains.
I use pretty much exclusively fiebings leather stains for my projects. I do paint and use block-out and finishes. But whenever I apply stain with a dauber I tend to get quite a bit on the back of the pieces, so I was thinking of using an airbrush for a cleaner end product. I was wondering if this would be possible or are most of the stains too thick?
Edited by Mike516
I don't see why not. Try thinning by 25%, if it spits then try 50%. If it's thin enough anything should spray thru an airbrush. You may have to experiment with pressure also.
Ok, I'm going to try the HF one and see what kind of results I get. Thanks.
