Members koreric75 Posted August 11, 2019 Members Report Posted August 11, 2019 14 minutes ago, Sangrati said: Message says Video unavailable for both the videos. Regards Sangrati https://youtu.be/TGuiha5S2oE here you go, saddlestitch in detail, just search nigel armitage on youtube and it'll get you there Quote Machines currently in use: Cowboy 3200, Adler 67-372, Singer 66, Singer 15-91
Members Sangrati Posted August 16, 2019 Members Report Posted August 16, 2019 On 8/11/2019 at 1:52 PM, koreric75 said: https://youtu.be/TGuiha5S2oE here you go, saddlestitch in detail, just search nigel armitage on youtube and it'll get you there Thanks a million. Really very nice. Hope, I will be able to do similar quality stitching some day. Regards Sangrati Quote
Members ehvhram Posted August 27, 2019 Members Report Posted August 27, 2019 Great videos, I needed some of these tips for another project.Awesome ! Quote
Members philg9 Posted March 25, 2020 Members Report Posted March 25, 2020 I suppose everyone has teir own way woith theor stitching, and for me,. that is based oin the type of work I do. As it is all heavy horse ( draught ) horse harness and tack, I am often working wiith thicker heavier leather than most other work where at times with strap work, it's 3 layers of 4 MM harness backs prepped, tacked up and hand sewn in the full 3 layers making anything from 15 - 18mm in total. It's technique much more than brute force and well polished awls. also bearing in mind is the job this harness has to go and do. It has to contend with a ton of horse of a single set of harness, coveriong strength, durability and as much if not more the fit and comfort for a heavy horse in work in work hauling heavy stuff and ploughing etc. The stitching has to reflect the rigours the harness will go through. Things like awl hole size are important on heavy horse harness, too big a awl hole is not so good for my work as I want as much leather between the stitches for strength. I see other leather work and the leading and lower ends of the slants the awl leave are wider than the row of laid stitches, wider slants help more to get a more pronounced herriong bone look to the stitch. Thread, I always use Somac waxed linen thread, 3 / 18 4 / 18 and 5 / 18 is the three common soze threads for me , Tiger thread is harsher on the surface of the raditional oak bark tanned hides I use from Bakers in Devon, UK, Tiger thread can have a tendency to cut through the surface especially when certain parts of the harness are really being put through its paces and the horse is working hard. I make ,my own wax from traditional pitch, beeswax and Rozin and melt it down and ball it up in cold water, no wax is beter for harness work and with the linen thread it works the best for strength as when stitching woith linen thread and proper harness waxed thread when you pull the stitches through it melts the wax a bit and then after some time, the wax sets hard around the thread which in time creates what is call a post inside the leather, makes like a cement which has extra grip to keep the leather together and stong even of the outer part of the stitch has worn away over the years in use. One thing when stitching, I work form the fornt of ny work, that's how my hands work best to do saddle stitch, I'll put the grain sode needle through forst, cross the needles over on the flesh side then the second needle is passed throiugh while pulling the thread of the first needle with it then when the second needle is half way through, I have the thread of the first needle in my right hand then I will make a clock wise loop over the second needle then pull the second needle through the loop then lay the stitch as usual, this creates what I suppose is a lock stitch insode the leather much like a sewing machine, but the purpose of doing this loop over the second needle each stitch is that this is what melts the wax I run the thread through pre stitching to then become what is the post inside the leather, If I didnt loop it so the two bits of thread inside the hole are not entwined as it were, the two thread sections would be seperate, if the stitching wears and or breaks the thread would just peel undone whereas by making this loop over the second needle each stitch, if the thread does break or wear on the oiuter surface then the post that is cemented from the wax inside the leather, then this will keep the leather together, it just makes it stronger again all round durable stitch. Quote
Members Tannin Posted March 26, 2020 Members Report Posted March 26, 2020 Good to hear from someone specializing in heavy leathers Philg9. I have some thick saddle leather offcuts which I use to make edge-protectors for large axes. I've often wondered what TPI is typically used for heavy horse harnesses - I expect you can enlighten us? Love heavy horses, magnificent beasts. Quite scarce now, around here anyway, so a treat to see them. At least one old thatched farmhouse had their old heavy horse harnesses hung on the wall for decoration for many years, not sure if they are still there, as the owners I knew have passed on. Happily Wadworths Brewery in Devizes still use horses for delivering locally and, of course, marketing. Quote Simple Leathercrafting
Members philg9 Posted March 26, 2020 Members Report Posted March 26, 2020 8 hours ago, Tannin said: Good to hear from someone specializing in heavy leathers Philg9. I have some thick saddle leather offcuts which I use to make edge-protectors for large axes. I've often wondered what TPI is typically used for heavy horse harnesses - I expect you can enlighten us? Love heavy horses, magnificent beasts. Quite scarce now, around here anyway, so a treat to see them. At least one old thatched farmhouse had their old heavy horse harnesses hung on the wall for decoration for many years, not sure if they are still there, as the owners I knew have passed on. Happily Wadworths Brewery in Devizes still use horses for delivering locally and, of course, marketing. Indeed, heavy leathers is not so common thee days but thankfully Bakers stil provide what I need. I cannot be doing with Veg tan for my work, it isnt half the leather of the oak bark in strength and dsurability. Heavy horse harness made form Veg tan stands out like a sore thumb, so not the right leather for it, so much so it does not even look right. As for TPI is typical. Most all heavy strap work like breeching seats and crippers, the breeching back strap, all retaining straps like brake straps, chain carrying straps that all feel the force of a ton of horse are done at 6 TPI, 6 is the magical number as it isnt course looking like a 5 TPI would be but still has full strength as your likely to get and it still leaves plenty of leather between each stitch. If heavy thick straps are sewn to close like 8 or 9 TPI then it weakens the leather somewhat. Next I use 7 TPI a lot for hame straps to latch the hames onto a collar, all driving reins, Bridle cheeks etc martingale and other decorative straps and parts, Clincher brow bands although will use 8 TPI for a brow band to go in a more refined set , then for some finer nose bands, more decorative parts especially on patent leather decorative parts especially for show harness I will use 8 TPI, then occasioanlly if I am making some decorative parts that are to be something that bit more special then I will occasionally break out a 9 TPI, so it is a combination of those three sizes mainly, I have irons up to 18 TPI but I dont ever use that fine, they just make the irons look a completr set on a tool board above my bench. They are all old irons as one thing that drivs me wild is the modern made irons, most of them have a teeth width that is far too wide for me. I much prefer narrow teeth irons. With those, you mark your stitch marks with them then after you have stitched through the work, the teeth are that wide you can still see the ends of the slants top and bottom of the stitch, this makes any piece of work have an ugly finish, just doesnt do it for me, also folk who punch awl holes far too big then necessary, then when you look at the stitching afterwards, you can see the thread but it's in a dirty great gash. with heavy horse harness, one thing that needs to happen is once you have pulled each stitch tight, it should close the hole you awled up a bit adding to the strength. Quote
Members Sheilajeanne Posted March 26, 2020 Members Report Posted March 26, 2020 (edited) Quote Indeed, heavy leathers is not so common thee days but thankfully Bakers still provide what I need. Wait - Baker's? Are they Mennonites? When I lived in Richmond Hill, there was a Baker's Harness Shop just a short distance from our house at Bathurst and Hwy. 7. They did heavy horse harness, but also catered to local English riders, and their needs: light tack and saddles, tack repair, etc. When the Bakers decided to give up their farm and sugar bush, and move to the States to join other Mennonites, a non-Mennonite named Carmen had already been apprenticed with Mr. Baker, and taken over the business. Since then, the shop has moved several times, and is now devoted to the needs of the local English riding fraternity only. They no longer make heavy horse harness. https://www.bakerssaddlery.com/articles.asp?ID=83 Of course, I'm wondering if there's a connection between the Baker you mentioned, and the family I knew in Richmond Hill, Ontario. Maybe the harness making branch of the business followed Mr. Baker to the States, though I know you are in the U.K. Perhaps another branch of the same family? Edit: not Mennonites, but Pennsylvania Dutch, which also includes Mennonites and Amish. I remember going into the shop where they sold maple syrup, and the women who were behind the counter had on long cotton print dresses, and lace bonnets. And the Bakers always used horsepower on the farm and in the sugar bush. https://www.yorkregion.com/news-story/1455409-family-comes-to-grips-with-thornhill-development/ Edited March 26, 2020 by Sheilajeanne Quote
Members Tannin Posted March 27, 2020 Members Report Posted March 27, 2020 (edited) Sheila, I think Phil was referring to the UK's last traditional oak tannery in the UK: https://www.jfjbaker.co.uk/ Not aware of any Mennonites in UK. Phil thanks, so 6 is the magic number. I figured it would like be less that 7 but thought you might use 4 or 5, so surprised to read that you use 7.8.9 quite often. Sound like 6 is perhaps what should aim for too. My (new) J. Dixon 7 TPI iron was originally created with excessively wide tines (i.e. made excessively long cuts for my needs) but I contacted them, sent it back and they altered it for me, without question or charge (they cost an arm and a leg to purchase though!). The tines are still pretty wide though. Last I heard, J. Dixon had closed or gone bankrupt. I did hear that descendants of George Barnsley (Geo. Barnsley) were starting up again a small way initially, a year or so ago. Edited March 27, 2020 by Tannin Formatted Quote Simple Leathercrafting
Members Tannin Posted March 27, 2020 Members Report Posted March 27, 2020 (edited) Phil, I am also impressed to read that you use a highly polished awl. Awl shaping , sharpening and polishing tips are always welcome here - if you care to share some? Being a relative novice I struggled a lot with that, even following some of Nigels excellent and helpful tips for stitching multiple layers (something he makes look straightforward of course!). The problem being me and my inadequately prepared awls no doubt. So more recently I have been using (hushed voice) a cheap Dremel-like tool to drill my holes after first marking them out with a pricking iron. Would prefer to get away from the Dremel-lie tool but it improved my results in the short term (being a cheap copy it has only 1/10th the power rating of a real Dremel - that's ok for my needs, probably safer that way!). I am a traditionalist at heart and dislike using power tools, esp. for leather work. Edited March 27, 2020 by Tannin Quote Simple Leathercrafting
Members philg9 Posted March 27, 2020 Members Report Posted March 27, 2020 15 hours ago, Sheilajeanne said: Wait - Baker's? Are they Mennonites? When I lived in Richmond Hill, there was a Baker's Harness Shop just a short distance from our house at Bathurst and Hwy. 7. They did heavy horse harness, but also catered to local English riders, and their needs: light tack and saddles, tack repair, etc. When the Bakers decided to give up their farm and sugar bush, and move to the States to join other Mennonites, a non-Mennonite named Carmen had already been apprenticed with Mr. Baker, and taken over the business. Since then, the shop has moved several times, and is now devoted to the needs of the local English riding fraternity only. They no longer make heavy horse harness. https://www.bakerssaddlery.com/articles.asp?ID=83 Of course, I'm wondering if there's a connection between the Baker you mentioned, and the family I knew in Richmond Hill, Ontario. Maybe the harness making branch of the business followed Mr. Baker to the States, though I know you are in the U.K. Perhaps another branch of the same family? Edit: not Mennonites, but Pennsylvania Dutch, which also includes Mennonites and Amish. I remember going into the shop where they sold maple syrup, and the women who were behind the counter had on long cotton print dresses, and lace bonnets. And the Bakers always used horsepower on the farm and in the sugar bush. https://www.yorkregion.com/news-story/1455409-family-comes-to-grips-with-thornhill-development/ Sheilajeanne, as what Tannin writw, the Bakers I refer to as I am in the UK is Bakers tannery in Colyton Devon UK. Thjey ar ethe oldest and last remianing tannery still producing the best quality oak bark tanned leather for the saddlery, Harness, leather goods and Cobbler trades. their leather is the best we have in England and far excells the quality of any Veg tanned leathers which I rarely use. I doubt they will have any connection with the Bakers you refer to. There has been a Tannery on the same site since mid 1700's by all accounts and it has been in the same family for generatons. Quote
