Members dikman Posted November 8, 2019 Members Report Posted November 8, 2019 As toxo mentioned if you replace the handwheel with a larger pulley that, coupled with a smaller motor pulley, will give you the equivalent of fitting a speed reducer. And it's simpler. I've done it on several machines. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Wellington Posted November 8, 2019 Members Report Posted November 8, 2019 Thanks again, Dikman. I might try that. I'd assumed that the pulley and handwheel were one unit that couldn't be separated. Even if that's the case, I guess I could just use the pulley itself as a handwheel, but if it's possible, I'd prefer to take out the existing pulley, replace it with a larger pulley, and then replace the original handwheel. Walking foot hot rodding! Quote Adler 67 GK373 • Pfaff 130-6 • Singer 201k-3
Members dikman Posted November 9, 2019 Members Report Posted November 9, 2019 Sorry mate, every handwheel I've seen has been permanently attached to the pulley! The shaft won't be long enough to attach another pulley as well as the handwheel. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Wellington Posted November 10, 2019 Members Report Posted November 10, 2019 (edited) Here's what I came up with. I tripled the effective length of the "throttle lever" on the servo motor by attaching a ~ 10" piece of aluminum tubing to it (tubing nearly flattened with a vise at ends before drilling). By lengthening this throttle lever, and putting a smaller drive sheave on the motor, and jamming a tennis ball (to act as a compression spring) under the back of the throttle pedal, I can set the motor speed to full speed, and still feather it to go slow with my foot. And if I want "full speed," I can mash down on the pedal and get it, without changing the dial position on the motor. (The other half of the answer, I think, is refining the fine motor skills in my leg and foot. I've always preferred knee throttle levers to work around this clumsiness. I hope I don't get turned around switching back and forth between machines but really look forward to having a knee presser lifter, and will probably copy it to retro-fit a knee presser lifter to my Pfaff 130...some of them came from the factory that way, but trying to find the lever part is a losing propositon.) Don't know whether this kludge will have the torque/punch for heavy leather, but it should work for my purposes sewing light leather and heavy fabrics, I think. Thanks again for everyone's help. This is a great website...it seems that every time I have another question about my new walking foot machine, Google leads me here (for example, I just found Wizcraft's simple solution for stopping bobbins from slipping on the bobbin winder shaft...thank you Wizcrafts!). W. Edited November 10, 2019 by Wellington Quote Adler 67 GK373 • Pfaff 130-6 • Singer 201k-3
Members Bert51 Posted November 11, 2019 Members Report Posted November 11, 2019 I have found that if you have your belt tension to tight, it will make it stiff to move the peddle. I slacken the belt so it is just tight enough to turn the pulley without slipping, will help. A new grippy belt works a lot better then an old hard belt. Bert. Quote
