Thanks Ron, I see what you mean on the rigging coming up to cover the front of the bars. That's an excellent idea, I'll have to give it a try on #4. I appreciate you taking the time to give me the info and the picture!
Tom, I do have the book that came with the Dusty video but I haven't looked at it or the video for quite some time. As best as I can recall it was a piece of plexiglass with a wood frame on two sides, think speed square with a window. The idea for using it was to set one side of the rigging then place the jig frame edges on the tip and bottom edge of the bar then mark whatever reference lines you wanted with a greese pencil on the plexiglass. Then you go to the other side, flip the jig around, place it on the bar the same way and use the reference marks to ensure the rigging is equal.
Here's how I set my rigging plates, I'm not sying it's the right or best way, it's just the way I figured out to do it. It's also probably a good idea to keep in mind this is based on me being in the middle of my 3rd saddle, I've done similar measurements on 2 other saddles that I repaired/replaced the riggins on. 1st - I tack the rigging on both sides, this is the part where I use my "good eye". 2nd - I move my work stand up against my bench with the saddle facing and square with the bench. 3rd - I measure from a reference point (leading edge, center back edge, pick your fav) on both sides of the rigging to the front of my bench (I hold a 4' level along the front edge of my bench top and a shelf that runs under it, you could also use a wall or any other flat surface). 4th - measure from a reference point to the floor on both sides. 5th - I tack a nail dead center on top of the horn (I've also placed the nail on the back side of the fork just above the hand hole, just make sure it's centered) loop a string over the nail ans pull down each side to a reference point. Once I've made these measurements I'll adjust one side or the other until they are all close enough that I'm OK with them.
Anyway, maybe that'll be helpful or maybe somebody else will chime in with a better way. I can tell you I've been riding the 2nd saddle I made for about a year and half and haven't noticed any issues with
the rigging being out of balance.
Best regards,
Josh
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
Josh,
When I mentioned the nail and string method, I assumed that everyone understood what I meant. Before you start putting any leather on your tree, first mark the centerline of the tree. Set your tree up against a straight level wall (behind your workbench, table against a wall, etc.). with a long side of the bar against the wall and the tree setting flat on the table. Take a tri-square or a leather square and hold it on the wall with the other leg extending onto the cantle and make a mark on the cantle (say at 7 inches). Do the same on the horn. Flip the tree around to the opposite side and make your marks at the same measurement (say 7 inches). Now, determine the midpoint of these marks, and you will have the center of the cantle and the center of the horn. Of course, you should always check your work, and the horn is the easiest by just finding it's center by using a compass. After finding the center of the cantle, tack a nail into the centerline mark, and you can use this mark to determine locating your rigging by using a string looped around the nail and pulling it down to a reference point on your rigging (say the corner of the rigging plate). A good example of how to do this is on Bill Gomer's saddle tapes. This way you can put your work anywhere and still have a reference point on the saddle that doesn't change.
Ron
Thanks for your description on how to set the string Ron. I'll have to try pulling from the center of the cantle as opposed from the center of the horn and see how they come out.
Best regards,
Josh
  • 2 weeks later...
Well, it's not 100% done but it's very close. The wife is very pleased and can't wait to put it on a horse. Here are some pictures of how it looks now and a few i took along the way.
I appreciate any comments and I'll be the first to note my cantle binding is horrible. Bad doesn't even come close and I know it, I'm not sure how to fix it on the next one but I need to figure it out. Other than that I'm fairly happy with it.
Thanks for looking,
Josh
post-19070-0-34968600-1360764223_thumb.jpost-19070-0-04846400-1360764230_thumb.jpost-19070-0-85123900-1360764243_thumb.jpost-19070-0-36628300-1360764252_thumb.jpost-19070-0-63231000-1360764264_thumb.jpost-19070-0-67658800-1360764272_thumb.jpost-19070-0-91275100-1360764312_thumb.jpost-19070-0-69675100-1360764322_thumb.jpost-19070-0-52501200-1360764332_thumb.jpost-19070-0-97711300-1360764339_thumb.j
Nice looking rig! I like the rough out and the tooling. After five years of leather work I'm just about ready to move into making my first saddle. I appreciate you putting your photos up here and getting feedback from the experts. It helps me understand the process a bit more.
Looking forward to seeing your next one.
Dave
Looks really great! I like the fact that its tooled but looks very practical at the same time.
Thanks Dave & Jinxed! I really like the combination of rough out and smooth out too. The border stamp pattern turned out really nice and it all seems to flow together. I'm pretty pleased with that aspect of this saddle.
Bob (BondoBobCustomSaddles) took the time to give me a few pointers in a private message, which was really nice of him and I'll share one of the things he brought up. One of things I didn't do very well was the blocking on the skirts. I'm sure the experianced makers all see it straight away but the novices like me might not be picking it up. It's easy to see that the back jockys don't sit down on the skirts like they should. It's not so much that they aren't tight but that my blocking wasn't good enough. I did block around the back of the bars and even tacked ths skirts into the edges of the bars while it dried but I didn't go far enough and once the intial blocking was done and the skirts had shrunk a bit I didn't force them back to where the blocked edge matched the skirt. Add that to the previously mentioned horrible cantle binding and this saddle doesn't look near as good as it should from the backside. Neither of these is a "fatal" flaw or has any "structural" impact in my very humble opinion but they certainly do detract alot. Anyway, I shared that so maybe others could avoid these problems. If you go look in the "Makers" page cac just posted some pictures of an awesome roughout association saddle where he nailed the jocky/skirt fit up and cantle binding.
Best regards,
Josh
Josh, the note I shared with you was strictly to point out a couple of points that would take your work to the next level. It must be noted that you already do a lot of things exceptionally well. If you were my student, you would get very high marks for balance of design, semetry of components and one of my pet items, edging. Nothing says "professional" like good clean, smooth, rounded and shiny edges of all the components. Horn, skirts, jockeys, rigging plates and so on. It's the perfection in the details that separates the good from the best. Keep up the good work!
Bob
Josh you did a good job on that saddle. I hope to finish up my third one in the next couple of weeks. I say that to let you know that I am far from being an expert.
If I were going to change anything on your saddle, I would drop the bottom line of the jockeys down so that they would cover the rigging. This would also make you need to drop the line on your front seat jockey. This was pointed out to me on my second one and so I more aware of it now.
CW
1 Thessalonians 4: 11,12
