Anybody who has a clever method of avoiding silicon thread lube all over the floor. My 441clone is squirts like an old tomcat, and my workshop floor is dangerously slippery. The lube is hard to wash of too. Any other solution than old towels and rags? How do you solve the this problem, please let me know.
Thanks
Tor
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Here in the states we have what's called oil dry used to clean up oil on floors,spread it around & sweep it up should absorb the oil,it is like kitty litter (which might work too)
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
I don't know how the thread comes out of the lube pot on your machine but if it goes through some kind of stripper tube the it sounds like the 'O' ring in the tube is too big for the size thread you are using or that it is missing altogether. Beware that if the ring is hard and unyielding it will add to the tension and you will have to loosen your tension to compensate. My pot doesn't have a thread exit tube so I have an elaborate capture thing made of pieces of sheepskin that keeps excess lube from getting out of the pot. I have a Union Lockstitch and so that's the top thread I'm talking about. My bobbin winder goes through strippers but I don't lube the bottom thread anyway.
I can't help on the prevention end of things, but as far as clean up of oils spills go, kitty litter is very good for this. The type that clumps up is to be avoided, though.
The magic is with the bentonite clay, as that is what is absorbing the oil. Just pour some on your oil, grind it around with your feet (wear shoes/boots for this), sweep up, and dispose of appropriately. That last part is at your discretion, as California has strict regulations on how oil, and oil soaked stuff can be disposed of.
This was a daily routine in the motor pool for cleaning up the floors and pavement.
Thanks for the replay, I will certainly look for some oil dry Bob. However, I will try to avoid that much excess oil spill on the floor.
Oltoot, there are no stripper tube or O rings in my lube pots. The thread comes out on the top, true a hole in the lid. Its the same kind of pot on two of my Adler's too (cast iron pots), it is no O ring in any of them.
The machine I am using now is a 441 clone, before I used my Adler class 5 and 105. The Adler`s have a shorter needle system (328), they never get as hot as the longer 794 system do. I never had any heat problems with the Adler`s, on this machine needle cooling is a must.
I am wondering about some spot air cooling instead of lube. Since I am building on a air foot lift on this machine, I have air for a mini cooler system.
http://www.exair.com/en-US/Primary%20Navigation/Products/Vortex%20Tubes%20and%20Spot%20Cooling/Mini%20Cooler/Pages/Mini%20Cooler%20System.aspx
You see the principals here
http://www.exair.com/en-US/Primary%20Navigation/Products/Vortex%20Tubes%20and%20Spot%20Cooling/Mini%20Cooler/Pages/How%20the%20Mini%20Cooler%20Works.aspx
And here is a other system on the youtube:
I looked at the mini cooler from Exair, its about 280 $. Its is smaller than the one in the video and have a magnet foot, it do not use much air. Silicon oil is not only a mess, but you cannot color the leather after sewing either. Silicon and paint do not mix.
Anybody who have used this Mini cooler system please give us your opinion.
I either have to built some kind of oil sump that gather up the excess oil or go for a air system. The air system looks like the easy way out of this mess.
Thanks
Tor
All you need to do is get air on the needle toards the top blowing down,you can get a piece of copper tubing (small 4mm) fasten to side of machine & aim the air towards the needle.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Maybe un cooled air is enough I never tried it? The mini cooler has a heat exchanger that cools down the air, then you do not have to run the compressor all the time. This system do not use much air, a open tube uses allot. Then you have to use a nozzle on the cobber tube, that might work. Thats easy to find out.
Tor
We had a customer binding carpet yrs ago that wanted to sew so fast it was burning the thread when they stopped,we made these up & they worked.It will use alot of air but you can vary the pressure w/a valve.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Yes, thats the cheapest solution. If I have some money that burns in my pocket I can buy this cool Little mini cooler system that pimps up my machine too.
Yes, I am a gadget/machine freak and I am not ashamed of it.
This silicon lube was more slippery than all other lubrication fluids I have ever seen, even my four legged friends has trouble crossing that workshop floor. I am afraid I am going to slide in to my old clicking machine, then its game over... tilt and flat pack...no more leather work for me. Two hundred and eighty dollars is a small price to pay compared to that. :rofl:
Tor
I think just air off your compressor will be enough. It is what is used on big sail/canvas/sunbrella machines. We use the air coolers (they blow cold air through thermal expansion) on our machine tools, especially for carbide tools which we run very fast. They work great, but use a really significant amount of air; you need a really big compressor system to use them. So just pipe some plain compressed air from your compressor and forget the coolers.
Art
