Members Grumpy1 Posted April 11, 2010 Members Report Posted April 11, 2010 (edited) UK Ray: Here is one more variation for the use of Fiebing Antique Stains. I have been using this method for about 40 years and have yet to find anything better. Start by diluting the heavy bodied stain with a 50/50 mix with Fiebing Bag Kote, this will give you a liquid about the consistancy of dairy cream. The resin based Bag Kote will make the antique stains WATER SOLUABLE, to a degree. I apply it with a small cheapie soldering brush, without the benefit of rubber gloves, brushing well down into the design impressions, doing the entire belt, wallet, checkbook, holster, item, in one five minute session. Put on ONE rubber glove, on whichever hand you will be rubbing with, and begin wiping with a dampened cotton cloth, until you get the desired contrast and color penetration. If desired you can take an old tooth brush and brush some of the deposits inside the stamp patterns and knife cuts to the surface where it can also be wiped away. The rubber glove will prevent the fingers from being stained from color that penetrates the cloth. Bag Kote is compatible with all finishes that I have lever use, including Lac-Kote,Tan-Kote and acrylics. Happy Toning! Grumpy1 Edited April 11, 2010 by Grumpy1 Quote
Contributing Member UKRay Posted April 12, 2010 Author Contributing Member Report Posted April 12, 2010 This thread seems to run and run... I finally got a great system together for dealing with antiquing that includes elements of all of the above. I now have paper on the bench that can be removed when it gets dirty, I have vinyl gloves so I can keep my hands clean and I have a range of applicators to make sure the filthy stuff stays on the leather and does not reach the dog. Personally, I find that mixing antiquing with Tan-Kote works best for me (thanks for that one, Kate) as it tends to dilute the antiquing and doesn't turn the whole project black. I just take a good dollop out of the jar with a spoon and drop it into a jam jar. Pour a healthy splash of Tan-Kote on top and stir until it feels about right - kinda like the consistency of thick custard. Okay - who doesn't know what a jam jar is? Who doesn't know what thickness custard is? We have a whole different language over here in the UK... I'll happily translate if required! Then I spread it around the project being careful not to get any on the back of the leather. I then leave it overnight - which is why all my antiquing jobs are left to the end of my work schedule. It makes a nice 'finish' (pardon the pun) to a busy day... LOL The following day I buff the surplus compound from the job and give it a final wipe over with some neat Tan-Kote to seal everything into place. Job done. Ray Quote
Members leathergrl Posted April 13, 2010 Members Report Posted April 13, 2010 On 4/12/2010 at 12:32 PM, UKRay said: This thread seems to run and run... I finally got a great system together for dealing with antiquing that includes elements of all of the above. I now have paper on the bench that can be removed when it gets dirty, I have vinyl gloves so I can keep my hands clean and I have a range of applicators to make sure the filthy stuff stays on the leather and does not reach the dog. Personally, I find that mixing antiquing with Tan-Kote works best for me (thanks for that one, Kate) as it tends to dilute the antiquing and doesn't turn the whole project black. I just take a good dollop out of the jar with a spoon and drop it into a jam jar. Pour a healthy splash of Tan-Kote on top and stir until it feels about right - kinda like the consistency of thick custard. Okay - who doesn't know what a jam jar is? Who doesn't know what thickness custard is? We have a whole different language over here in the UK... I'll happily translate if required! Then I spread it around the project being careful not to get any on the back of the leather. I then leave it overnight - which is why all my antiquing jobs are left to the end of my work schedule. It makes a nice 'finish' (pardon the pun) to a busy day... LOL The following day I buff the surplus compound from the job and give it a final wipe over with some neat Tan-Kote to seal everything into place. Job done. Ray Ray, thanks for the reply. So let me get this straight. When you mix it with tankote (with no other treatment to the piece prior to application), the piece does not go too dark even after sitting overnight? I hope this works, because I am nervous about messing up my piece that I painstakingly tooled. I'm sure you can understand that sentiment. I am going to try it out. Quote
Ambassador Luke Hatley Posted April 13, 2010 Ambassador Report Posted April 13, 2010 (edited) On 4/13/2010 at 1:51 AM, leathergrl said: Ray, thanks for the reply. So let me get this straight. When you mix it with tankote (with no other treatment to the piece prior to application), the piece does not go too dark even after sitting overnight? I hope this works, because I am nervous about messing up my piece that I painstakingly tooled. I'm sure you can understand that sentiment. I am going to try it out. **********************************************************************88 Leathergrl... you sometimes have to try things out on a Practice piece. Edited April 13, 2010 by Luke Hatley Quote
Contributing Member UKRay Posted April 14, 2010 Author Contributing Member Report Posted April 14, 2010 On 4/13/2010 at 2:27 AM, Luke Hatley said: **********************************************************************88 Leathergrl... you sometimes have to try things out on a Practice piece. As Luke says: sometimes the only way to know if something will work is try it on a test piece before hitting the important stuff. This is much harder to do when you are starting out as there never seems to be any scraps of leather left when you need one. After a while it gets easier... LOL Practise pieces make perfect! Ray Quote
Members leathergrl Posted April 15, 2010 Members Report Posted April 15, 2010 On 4/14/2010 at 1:34 PM, UKRay said: As Luke says: sometimes the only way to know if something will work is try it on a test piece before hitting the important stuff. This is much harder to do when you are starting out as there never seems to be any scraps of leather left when you need one. After a while it gets easier... LOL Practise pieces make perfect! Ray I tried the tankote mixed with the antique gel from tandy on a celtic braided piece and I must say that I am very happy. I doused the whole thing in it but wiped off the excess and let it dry over night. I was happy that the piece did not darken and ruin- THANK YOU UK RAY. I am so happy. I will click my heels together. Quote
Mike Craw Posted April 21, 2010 Report Posted April 21, 2010 Hey Ray! I don't know if you've seen the YouTube video that Keith Valley did on antiquing, but he shows how he does a tooled saddle part. If you search "Cowboy Saddlery" there will be a list of videos on carving and tooling, and also the one he did on antiquing. Hope this helps. I notice he does not use a dog in his process. Mike Quote
