Thought I'd share something from a different perspective, but still machines to sew leather goods. Just faster. We're doing a contract for the US Navy making welding jackets. It's a nice 4 oz suede. We are making our way through 6 pallets of hides stacked about 4' high each. Needless to say, a lot of leather. The spec calls for Kevlar thread, tex 90. Wow, that stuff's expensive! The machines I set up are a Singer 300W flatbed dbl needle chainstitch. I set the needle gauge to 3/16". That is used to create a lap seam with two row of stitching which was required. The other main machine is a Singer 261-3 feed off the arm dbl needle chainstitch. It's not a cylinder machine, but rather a feed off the arm machine that can close a sleeve with little effort. Since both those machines are chainstitches, no bobbins. On the 300W I made a speed reducer as well as making a needle cooler which you can see in the picture is actually under the throat plate and blows air as the needles decend. I'm also running both the needle threads and looper threads through a silicone bath. The 261 has just the needle cooler. The original motor has plenty of torque. I'm using 62x40 needles with a spear point, size 20. Chainstitch machine needles deflect quite a bit more than a lockstitch so the heavier needle must be used.
Other misc. equipment required are a Brother progammable bartack, an automatic rivet machine, and an old manual Stimpson kick press for the snaps and grommets. Total time to produce one complete jacket is about 18 minutes. That doesn't include cutting time. The cutters are using Eastman 2" round knives after laying out each hide with masonite templates. I'll have enough scrap suede for the next 10 years!
Regards, Eric
post-33297-0-04233100-1376630327_thumb.j
post-33297-0-62258900-1376630339_thumb.j
post-33297-0-23888500-1376630353_thumb.j
post-33297-0-33497900-1376630364_thumb.j
Edited by gottaknow
That is a interesting machine, heck it's all interesting.
I'm old enough to know that i don't know everything.
Eric thanks for the glimpse in the factory setups, A very good eye opener for me and Just thanks for your help.
uh more pics Please ! beings im last for the moment here and semi retired/repurposing myself, I know your busy.
Im starting the new to me venture of a 212G140 and this forum and its group has shared many valueble tips.
Have a Good Day
Hello Eric, nice set up and interesting reading. The needle cooler you made, does it only blow when the needle descend or all the time?
( I know we spoke about this before, but you wrote"when the needle descend") :)
Thanks
Tor
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Great read Eric. See!! Folks are interested in what you do and say. :)
ferg
Eric,
I find this very interesting too. Reading through this and a few other posts you have made my main question to you is about your house. Is it filled with prototypes of what you are making or are you not allowed to bring stuff home? I know I would have difficulty not bringing one of everything home.
Aaron
Tor, the air flows through an air switch that is activated when you start sewing. It blows air across the needles below the plate. When you stop sewing, the air stops. Arron, we have hundreds of samples at the factory. I will bring one home on occasion if it needs some engineering.
Regards, Eric
Wow! Many years ago I worked on the production floor at Flags Unlimited. We sure could have used a guy like you around :) If we had a machine break down, we were instructed to just "set it aside" and replace it with another half broke down machine. Loss of production time was incredible! We had a mechanic that came in part time but he didn't really put a lot of effort into the job. He was probably overwhelmed by the huge stack of broken machines in the back corner LOL
This is pretty cool, definitely big leagues manufacturing
How many jackets to produce in the contract?
Are they one size fits all?
We estimated about 2000 units in 3 different sizes. The hides are decent and we don't have to worry about scars etc. I think we'll be finished in October. We got this contract because another factory couldn't make their machines sew them with quality. We redesigned them and they loved our samples. They were trying to do a full felled seam (4 layers) I changed it to a simple lap seam since leather doesn't unravel. The other company simply didn't have the means or machines to make them. We'll likely get to make chaps as well.
Regards, Eric
