thanks cyberthrasher, thats another one i want to try....... I love this site.......
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
My question is: How does anyone have enough leather dust to mix with the rubber cement? Or are you making the dust and how?
All those little trimmings you cut off (cutting to size as well as edge beveling) and holes you punch out and other garbage that's too small - grind it up in a blender.
I'm about to the point of needing to pitch some. Finally forcing myself to throw more of the small stuff out. I've got a buddy that makes a lot of belts. He's taken to giving the bellies and strap ends to a local Boy Scout troop when they build up too much.
  • 2 weeks later...
Well think I've got it organized for now. :) I got a new 3 shelf rack and baskets. Sorted all the scrap while throwing out the true crap. Taking this bit of time to organize has already made a huge difference in making better use of my scrap. I also have a couple items that I make regularly so if I have leather that fits a certain pattern piece I will cut it and store it for future use.
Last weekend I went through two large totes of scrap and threw away enough small non-usable pieces to nearly fill up one of them. It's the first time I've went through my scrap box since I started a couple of years ago. I try to be as efficient as possible!
I have a limited space otherwise I would have kept it to try out the putty idea!
http://www.cgleathercraft.com
Member of the Iron Brigade.
  • 2 weeks later...
when I get too much....I sort the big and desirable pieces into 1 bin and donate the other to a school / group .. I recently donated about 10-15 lbs to a group for holiday decorations. Or you can always ebay them
How long do you keep old (well organized or not :) ) pieces of leather? I assume it gets too old to use but I found my Dad's scrap bag and I'm wondering if I'm working too hard using old leather compared to new. There's no leather shops in my area to compare.. I also don't want to be wasteful if it's not causing problems.
Thanks- Greg
After a slight hiatus (at least 25 years) I dug out my tools & the 1/2 side of 2.5mm Tandy leather I still had. A tad green in places & a little..ahem...firm, but it was still useable after a little TLC.
I have only used it for projects that are "backed" - clocks, keyracks etc. & although a little problematic to cut it worked ok.
So absolutely no need to throw away any leather any time soon :rofl:
Example of the old leather!
post-29641-0-67258700-1390432058_thumb.j
  • 4 weeks later...
I had a piece of black kudu hide from when I was at school in Zimbabwe and at the tender age of 35 I made a tooled tablet cover and it is wonderfully soft. so don't throw anything out. just keep it nicely and it will work out.
cheers Alex
Alex
Eveything is OK in the end. If it's not OK, it's not the end.
