Are there any tips to cutting shallow, subtle arcs or curves in leather. On a simple billfold for example. If I wanted the lip of a card pocket to have a shallow dip, rather than be a straight line across. What the best way to measure and cut that?
I would use a template made of paper cut the same size.
Fold the paper, mark your line, cut on the line and then unfold the paper and there's your template.
  • Ambassador
I use a protractor upside down a lot. You can use a small bit of it for a shallow dip or just lower it for a deeper and wider curve.
I use can lids and jar tops too
Pete
So I guess my hang up is how to physically cut the arc? What's the best way to make rounded cuts? Most cuts are straight and I normally use a hobby or x-acto knife
Push down hard on the plate and pull your knife along the edge.
A french curve will work well. On my patterns I cut them from rawhide or linoleum. Then you can use it to cut around with out messing up the edge. Rob
I use a compact disc as a guide and make the cut with an x-acto knife. I don't try to cut through the leather all the way on the first pass, rather, I make 2-4 light cuts, one over another until I get all the way through the leather...
The disc may or may not work for you depending on how much of a curve you need. It works well for the pockets of card wallets that I make. Hope that helps!!! :)
So while it will help of you have a hard edge to but up against, do yo need that, or can you cut it in stages with a knife, multiple cuts getting deeper, after you've traced your pattern?
if you mean can you cut it in stages - going deeper with each pass? you can do it that way.
