I have been watching Nigel Armitage and Ian Atkinson on YouTube, using pricking irons. It seems that they used two ways, one just to mark the hole spacing, and the other to completely punch the holes instead of using the awl. Which way do you prefer to use? Or do you do both and it depends on the project?
Thanks,
Chris
I've found that pricking irons, as opposed to stitching chisels, is that the teeth often widen from the point all the way up to the head of the tool. If you punch in too far, I've found it easy to weaken the leather in between the stitches because of this. So, I always prick, never punch.
Thank you guys!!!
Chris
Well, anyone who has used a punch to mark a position in any material will you that one solid blow is better than tap tap tapping away. And a blow that in one piece of leather will simply prick an inch of stitch marks will completely perforate a different piece.
