mlapaglia Posted February 10, 2014 Report Posted February 10, 2014 (edited) I made a belt for a dear friend. He would not let me line it. Im not sure what his reasons were. Anyway, the belt is H.O. 8-9 oz About 40 inches overall finished length. 5 holes Vinagroon color and Resolene finish. Hand stitch. (You know this is a true friend when I hand stitch a belt since I own a machine). He just called and told me the leather between hole 3 and 4 just tore through. I have never had this happen. The holes were spaced 1" apart and the leather didnt look like there was any problems with it. I have not seen it yet but its on the way. Hard to say what went wrong but He says he sat down at the table and it tore. He is not at all heavy and in good shape. Could he have just had it too tight? Could it be a bad section of the leather? Any ideas? Im off to start the replacement. Michael Edited February 10, 2014 by mlapaglia Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members Troy Burch Posted February 10, 2014 Members Report Posted February 10, 2014 I replace alot of sturrip straps because the quick couplers have worn sharp and cut through the holes. Wondering if he wears an old buckle thats worn down the post? Quote
mlapaglia Posted February 10, 2014 Author Report Posted February 10, 2014 Troy, its a new buckle but it doesnt mean that the post does not have a sharp edge on it. Ill check. Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members camano ridge Posted February 10, 2014 Members Report Posted February 10, 2014 (edited) I know you are familiar with using vinagroon. However when you get the belt back take a close look at the leather with a magnifying glass and feel the leather to see if it is brittle or crumbly. It is possible that that area either did not get neutralized well enough or got to much baking soda in that area (maybe not getting rinsed enough). Edited February 11, 2014 by northmount Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members Red Cent Posted February 10, 2014 Members Report Posted February 10, 2014 You didn't mention anything about oiling the leather after the VG. I use VG a good bit but it will definitely dry out the leather. After mine dries from the VG, I lay it flat and really smear on the NeatsFoot Oil. On raw veg tanned, I usually wipe off excess and buff a little. With the VG I let it be and let it soak in the leather. I don't put the oil on the backside. And I do this on any leather that I dye. Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members Fowlingpiece Posted February 11, 2014 Members Report Posted February 11, 2014 I would guess a problem with the vinegroon. Quote
mlapaglia Posted February 11, 2014 Author Report Posted February 11, 2014 I know you are familiar with using vinagroon. However when you get the belt back take a close look at the leather with a magnifying glass and feel the leather tosee if it is brittle or crumbly. It is possible that that area either did not get neutralized well enough or got to much baking soda in that area (maybe not getting rinsed enough). Good idea thanks. Quote The key to immortality is first living a life worth remembering. Bruce Lee
mlapaglia Posted February 11, 2014 Author Report Posted February 11, 2014 You didn't mention anything about oiling the leather after the VG. I use VG a good bit but it will definitely dry out the leather. After mine dries from the VG, I lay it flat and really smear on the NeatsFoot Oil. On raw veg tanned, I usually wipe off excess and buff a little. With the VG I let it be and let it soak in the leather. I don't put the oil on the backside. And I do this on any leather that I dye. I didn't mention it because i didn't think to. I did oil it with pure Neetsfoot oil. Nothing goes out the door without getting oiled up. Since there is always a 6 back or 3 in the fridge even a few customers have gotten oiled up. The only other thing I can think of is the owner of the belt lives in Seattle and wore it in NY to the to the superbowl. It might have broken in shame. (For those that don't know I live in Denver ) Quote The key to immortality is first living a life worth remembering. Bruce Lee
Members camano ridge Posted February 11, 2014 Members Report Posted February 11, 2014 I think you got it wrong. It probably broke because he was bursting with pride. Go Seahawks. I live just north of Seattle Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
mlapaglia Posted February 11, 2014 Author Report Posted February 11, 2014 I think you got it wrong. It probably broke because he was bursting with pride. Go Seahawks. I live just north of Seattle You may be right. The Seahawks did a great job this year. Quote The key to immortality is first living a life worth remembering. Bruce Lee
