Members Shaunny Rotten Posted February 19, 2014 Members Report Posted February 19, 2014 I have a project that requires a seam with no stitching. I've always had less than satisfactory results when using glue in the past, however this seam will have to rely on it 100% It's 1/8" thick leather wrapped around a roughly 1 1/4" dowel and the glue surface is a scarf joint with a roughly 9/16" contact patch. Ideally I would like recommendations for a product available from Tandy as I have one close to me but if their products wont work I am willing to look elsewhere. Shaun. Quote
Matt T Posted February 19, 2014 Report Posted February 19, 2014 (edited) Barge cement will work, and is available at Tandy. Just make sure to use it properly. Coat both surfaces, let dry for a bit, and then press together. Try a practice piece first, of course. If you want PVC, try this: http://apps.webcreate.com/ecom/catalog/product_specific.cfm?ClientID=15&ProductID=18847 Produces a VERY strong bond. Edited February 19, 2014 by Matt T Quote Leathercraft supplies
Renaissanceman Posted February 19, 2014 Report Posted February 19, 2014 I have tried a lot of adhesives on various projects. Have to agree with Matt T, Barge the best. Quote
Members Shaunny Rotten Posted February 20, 2014 Author Members Report Posted February 20, 2014 (edited) Thanks folks, I'll give it a shot over the weekend. On a side note, has anybody had any success with Shoe Goo? Edited February 20, 2014 by Shaunny Rotten Quote
Members BDAZ Posted February 20, 2014 Members Report Posted February 20, 2014 I also recommend Barge. I believe it's available in tubes as well. Cya! Bob Quote
Members papaw Posted February 20, 2014 Members Report Posted February 20, 2014 I've used Shoe Goo but don't think it's strong enough for anything like that. Quote Papaw Indiana Calumet Area Leather Guild Happy to be old enough to know better, but young enough to still do it !!
Members davidgould Posted June 8, 2014 Members Report Posted June 8, 2014 Hope it's OK to necro this thread as I suspect the above information isn't outdated.I've seen reports that the newer toluene-free Barge isn't nearly as good as the old one.I'm just looking to reglue unidentified rubber/plastic soles to leather uppers. Just two pairs of relatively cheap shoes so I don't need much and price is a factor.I am also based in the UK.Thanks for your help. Quote
Members Tex Posted June 25, 2014 Members Report Posted June 25, 2014 I use weld wood. It's a whole lot cheaper than all that high $ stuff & holds durn good. Quote
Members Hi Im Joe Posted June 25, 2014 Members Report Posted June 25, 2014 I also use DAP weldwood. Works really nicely. Quote http://www.sevenhillsleather.com/
Members cgleathercraft Posted June 25, 2014 Members Report Posted June 25, 2014 I was using Weldwood in the red can till my wife said it stinks too much. Switched to the green can (non-flammable formula) and it holds well. Not as good as the red can but better than everything else I've bought. Quote http://www.cgleathercraft.com Member of the Iron Brigade.
Members camano ridge Posted June 25, 2014 Members Report Posted June 25, 2014 I have been using the weldwood green lable non flammable for 4 years. It works great for me and has very low odor. Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
Members davidgould Posted July 9, 2014 Members Report Posted July 9, 2014 Thanks for the replies. Unfortunately Weldwood is totally unavailable in the UK. Even Barge doesn't seem to be available at the moment. Can't get Masters. Seem to be able to get Renia glues though eg:http://www.ebay.co.uk/itm/Shoe-Repair-Glue-Renia-Klebfest-30g-Tubes-Suitable-for-Leather-and-Rubber-/380735974671 Quote
Members BDAZ Posted July 9, 2014 Members Report Posted July 9, 2014 Find out what local shoe repair guys use for gluing soles onto shoes and get some. Cya! Bob Quote
Members camano ridge Posted July 9, 2014 Members Report Posted July 9, 2014 I have not used Renia, how ever Electrathon a member on these forums has. You might PM him and ask for his input. See his post #6 at this link http://leatherworker.net/forum/index.php?showtopic=50905&hl=%2Brenia+%2Bglue#entry329444 Quote https://www.facebook.com/CamanoRidgeCustomLeather?fref=ts
