Members Missvlaa Posted August 8, 2016 Members Report Posted August 8, 2016 Thank you so much. This will be my first try with leather. My third anniversary is at the end of August and it is the "Leather Anniversary" so I thought I would try to make my husband a wallet. Quote
Members JHobbs Posted January 14, 2017 Members Report Posted January 14, 2017 Thank you for sharing! Quote
Members Haellyn Posted January 15, 2017 Members Report Posted January 15, 2017 Thanks for posting this template. The end result looks nice and the directions are easy to follow. I got a different template out of a Stohlman book, so I'm going to try making both. Quote
Members Mattsbagger Posted January 15, 2017 Members Report Posted January 15, 2017 Thanks for sharing. I've used it to make a couple wallets. I use 3 oz on inside 5 oz on outside. Seems to work out good. Quote
Members Ordiedaddy Posted February 2, 2017 Members Report Posted February 2, 2017 Great pattern! Thanks for sharing it. Look forward to making one. Quote
Members Edge2886 Posted April 5, 2017 Members Report Posted April 5, 2017 Thanks for the pattern this should help out a lot with my fledgling leather work Quote
Members KelvinL Posted October 5, 2017 Members Report Posted October 5, 2017 Thanks a lot for this pattern! will try this out. Quote
Members cradom Posted October 5, 2017 Members Report Posted October 5, 2017 And I just bought a 6 slot pattern last week Thanks a lot for the share! Quote
Members Bennyg11 Posted October 25, 2017 Members Report Posted October 25, 2017 Thank you for sharing Quote
Members jDev Posted November 10, 2017 Members Report Posted November 10, 2017 Many thanks from France for this lovely tutorial and pattern, will post pics when I start and finish this Quote
Members KingsCountyLeather Posted November 11, 2017 Members Report Posted November 11, 2017 Thank you! I will try this out. Quote
Members DocDaddy Posted November 13, 2017 Members Report Posted November 13, 2017 nice! Thank You Quote
Members YinTx Posted November 15, 2017 Members Report Posted November 15, 2017 Thank you for sharing your pattern! Here is my go at it: YinTx Quote
Members Scoutmom103 Posted December 9, 2017 Members Report Posted December 9, 2017 Thank you for sharing. I am viewing various designs for minimalist wallets/card holders for my daughter. She wants one with a coin pocket, since she doesn't like to carry a purse, just her cards, a few bills, and coins. I appreciate having a place to learn, and eventually share about leather working as I hone my skills in this wonderful medium. Quote
Members navyrob74 Posted December 15, 2017 Members Report Posted December 15, 2017 Thanks for the pattern, I can't wait to try it. This will be my first wallet Quote
Members frenchy07 Posted January 12, 2018 Members Report Posted January 12, 2018 Thanks! Going into my files for later. Quote
Members Wildo Posted January 13, 2018 Members Report Posted January 13, 2018 Thanks for sharing. Quote
Members Brianm77 Posted January 17, 2018 Members Report Posted January 17, 2018 Thanks for sharing, Ducjes! Quote
Members koreric75 Posted March 7, 2018 Members Report Posted March 7, 2018 Thanks for the share, I've put together a few .svg format wallets and other designs with inkscape, it would be easy enough to convert to a jpg or pdf...however a few of mine didn't turn out great so lots of trial and error. I usually try the first draft with card stock (cut on dye cutter) to make sure things look basically correct, then check if i need to adjust for material thickness etc then try out on scraps or economy veg if it has an image that i want to use the scoring tool to imprint then tool. Attached is one i made for the kids. It's a baseball style hackysack. The stitching holes lined up near perfect and i used a baseball stitch to close it. The seams may not be the best for keeping in the guts so i used a party baloon and filled with the Polypropylene plastic pellets. It started out pretty solid but the more you kick it around the better it gets. I used some white stiff garment leather that i picked up at Tandy for $6 for a huge piece. It hasn't started to peel yet but i imagine it will eventually. baseball.svg Quote
Members koreric75 Posted March 9, 2018 Members Report Posted March 9, 2018 I really like this design for a simple lightweight wallet. Again thank you, and here's my attempt at making it. https://imgur.com/a/zucGi Quote
Members alex20000 Posted March 13, 2018 Members Report Posted March 13, 2018 On 4/4/2014 at 2:41 PM, ducjes said: Edited April 4, 2014 by ducjes Expand Thanks for the share! Looking to creating a wallet pattern too and this helped. Very detailed! Quote
Members BrokeBadger Posted March 27, 2018 Members Report Posted March 27, 2018 This will be my first attempt at making a leather wallet. Many thanks for the template. Quote
Members NealPoole Posted June 27, 2018 Members Report Posted June 27, 2018 tHANKS DUCJES FOR THE DOWNLOAD. Quote
