Contributing Member JLSleather Posted April 20, 2014 Contributing Member Report Posted April 20, 2014 Nice shading. Black plus ANYthing can be tough! Quote
Moderator immiketoo Posted April 21, 2014 Moderator Report Posted April 21, 2014 Very well done. Quote
Members Ghaniba Posted May 4, 2014 Members Report Posted May 4, 2014 Good work bud. Funny I should find you here again doing a job I'm looking for inspiration for... Looking to do a seat for my '78 Yamaha XS650 Special. Did you do the foam work inside the seat as well? If so, what did you go with? Dave Quote
Members Solofalcon Posted May 4, 2014 Author Members Report Posted May 4, 2014 Thanks Dave, I did not have to work with the foam at all. The customer gave me a finished seat with vinyl on it and I removed the vinyl and made my pattern from it. I did do some looking around for info on foam and see that high density foam is the preferred choice which you can find at a craft store and some people use an electric turkey knife to shape ant trim the foam. Sorry I don't have more for you. Good luck, Kevin Quote
Members OdinUK Posted May 4, 2014 Members Report Posted May 4, 2014 Very nice work. May I ask roughly how long it took from start to finish? Quote
Members Wild Bill46 Posted May 6, 2014 Members Report Posted May 6, 2014 Man O Man, This is very much a BEAUTIFUL seat, Man. !!! No matter the time it took, or materials used, its Artistry ! Quote
David Posted May 7, 2014 Report Posted May 7, 2014 Very nicely done. It looks like you used some sort of gloss finish on the black. Be careful doing this, a bit too much gloss and you may find the finish cracking. If the finish cracks it will begin to peal off. My advice would be to apply your gloss with a lint free rag in thin coats and rub it in. I understand the need for something over the black dye because the black WILL rub off. The gloss will prevent that for a while at least. However as soon as you wear off the gloss, the black will begin to rub off also. Quote
