rcsaddles Posted June 9, 2014 Report Posted June 9, 2014 I am trying to make a leather tube for a spyglass to fit in. I am windering if anyone has any suggestion on the best and easiest way to stitch the bottom in? I have not done one of these before and would greatly appreciate some info before I get started. Thanks, Quote
Members Dwight Posted June 9, 2014 Members Report Posted June 9, 2014 Take a look at this, . . . it is pretty much what you want to do, . . . but for a holster. May God bless, Dwight Quote
Members bucksnort Posted June 9, 2014 Members Report Posted June 9, 2014 Joe, I did one recently for a spotting scope. I laced it with rawhide. Sorry, I didn't think to take pictures. Looked nice & the rawhide lace will take a lot abuse & wear well. Buck Quote
Members bucksnort Posted June 9, 2014 Members Report Posted June 9, 2014 Just had another thought scrolling down thru the forums, there is a forum for archery quivers that should have some good info. Buck Quote
Members CTaylorJr Posted June 9, 2014 Members Report Posted June 9, 2014 (edited) I made one recently and inset the bottom after wet forming to the diameter I needed. I used a hole saw to cut the mould piece with. With the "open" end of the bottom piece pointing down, I placed the piece in place, anchored it with a few push pins, and then used my awl to push through for sewing holes. To make sure the piece stayed in place, and to provide a bit of resistance, I held a pink rubber eraser on the inside of the bottom and pushed the awl into that through the leather while also holding the needed pressure on the bottom to keep it in the correct location? Did that help or is it as clear as mud? Edited June 9, 2014 by CTaylorJr Quote
Members WinterBear Posted June 9, 2014 Members Report Posted June 9, 2014 (edited) There are some nice examples of various types here too. http://leatherworker.net/forum/index.php?showtopic=44514 leatherworker.net/forum/index.php?showtopic=49762 leatherworker.net/forum/index.php?showtopic=55236 leatherworker.net/forum/index.php?showtopic=54509 Edited June 9, 2014 by WinterBear Quote
Members ramrod Posted June 9, 2014 Members Report Posted June 9, 2014 i believe stohlman's first book on hand stitching leather has instruction on making a dice cup. it's got good illustrations. i made the dice cup. and if I can do it, anyone can. of course, if you don't have this book.....well......i'll shut up now. Quote
Members LTC Posted June 9, 2014 Members Report Posted June 9, 2014 Depending on the diameter of your spy glass, you'll probably need to make or acquire some curved needles to saddle stitch it. Quote
rcsaddles Posted June 10, 2014 Author Report Posted June 10, 2014 Thank you all for the information. I think I have a plan now. Buck, good idea on using rawhide, I think I'll do that. Ramrod, what can I say? I know where you are coming from. I'll post a picture or two when I am finished with this. Thanks again. Quote
