Doc Reaper Posted June 27, 2014 Report Posted June 27, 2014 What is the thinnest Leather a CB4500 will sew! Can it sew leather to make biker chaps or should I use something different? This might be a question with only one outcome. Quote Doc Reaper
Moderator Wizcrafts Posted June 27, 2014 Moderator Report Posted June 27, 2014 What is the thinnest Leather a CB4500 will sew! Can it sew leather to make biker chaps or should I use something different? This might be a question with only one outcome. I sew chaps and zippers on jackets with my CB4500. I rethread it with #138 top and bottom, using a Schmetz #23 leather point needle. Back off the bobbin tension (should happen automatically if changing from previous #277) and top tension. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Doc Reaper Posted January 13, 2022 Author Report Posted January 13, 2022 Let’s update this just a bit, it’s been just under 8 years, i founder a thinner needle plate (thanks Aussie) and now my Cowboy 4500 will sew whatever I need it to! Quote Doc Reaper
Members TomE Posted January 13, 2022 Members Report Posted January 13, 2022 14 minutes ago, Doc Reaper said: Let’s update this just a bit, it’s been just under 8 years, i founder a thinner needle plate (thanks Aussie) and now my Cowboy 4500 will sew whatever I need it to! Ditto for my Cobra Class 4. The narrow plate and feed dog handle the heavy and light leather projects without a lot of fiddling. @Doc Reaper do you have any uses for the original plate/feed dog now that you're using the narrow setup? Quote
Doc Reaper Posted August 9, 2022 Author Report Posted August 9, 2022 On 1/13/2022 at 7:15 AM, TomE said: Ditto for my Cobra Class 4. The narrow plate and feed dog handle the heavy and light leather projects without a lot of fiddling. @Doc Reaper do you have any uses for the original plate/feed dog now that you're using the narrow setup? Sorry TomE, I just found this, it’s just sitting in the CB4500 ditty drawer (I seriously have to make a larger unit to store items in like drawers) why do you ask??? Quote Doc Reaper
Members PAMuzzle Posted August 11, 2022 Members Report Posted August 11, 2022 I bought the same plate/feed dog and was able to sew 2 layers of t-shirt material with #277 thread. It was a test and that was the smallest thread I have. Quote
Members dikman Posted August 11, 2022 Members Report Posted August 11, 2022 The thread would have been thicker than the material! Seriously, that is a pretty good effort. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members PAMuzzle Posted August 11, 2022 Members Report Posted August 11, 2022 (edited) Yeah it is. Puckered a little but I did not change tension from my leather settings. Did not pull material into machine. Edited August 11, 2022 by PAMuzzle Quote
