Howdy;
Just wondering what you folks with more computer knowledge than I think of buying a factory refurbished laptop?
we have found one that looks like it should work quite well for us, it uses the XP not the vista which is great because my wife made my website with frontpage and is does not work with vista, also we already have the office software that will work with XP not vista. So we really want a computer with XP not vista. I just am not sure if we should be concerned with the refurbished part? I would appreciate your opinions.
thanks much
check out www.stevemasonsaddles.com
check out my saddle blog
Howdy;
thanks much
I think you should be quite fine. We have a refurbed laptop (Toshiba) and it has served us fairly well. We have since switched to Macs now, but still use the toshiba for my wife's embroider machine.
Marlon
Marlon
Typically, a refurbished laptop was sent to a customer, and they returned it right away due to wrong model, wrong options, etc. They're more like "open box specials" than something that was broken and then fixed. There is a chance that you're getting one that was broken and fixed though, and that's fine as well. Whatever part wasn't working will have been replaced and tested, and it should be fine. Remember that with computer parts, they generally either work, or they don't - they don't wear down slowly over time. The only exception to this would be the very few moving parts: hard disk drive, optical drive, keyboard, fans. And all of those parts are modular and easily replaceable.
If there's a warranty still available on the laptop, that's a good indicator of what kind of shape it's in. Go for it.
Edited by hivemind
  • Ambassador
I'm partial but that said- give Mac's a try. They came out with the new Macbook last tuesday and they dropped the price of the original to below $900.00(new) They have a lot of re-furbished and returns so THEY are really a bargain.
I'm not too literate so the Mac is perfect. Point and click.
pete
If you can get the machine for a good price then go for it. Software is software and can generally be cross compatible: Vista requires more memory, or the comp. can still run xp. Or you could move to open source linux OSs. The biggest issue is getting the motherboard and body together, and connected to a power supply. After that all you really have to have is some USB2 ports. If you've got that, you can plug any periferal you want into it.
Mike DeLoach
Refurbs from reputable companies are fine. Most have at least a one-year warranty. If you have the Office disks, you can install older versions of Office on Vista. XP is a stable extablished operating system, but Vista is more fun to use. If you get Vista, get as much memory as possible (2 gigs minimum). If you get XP, try to get the XP disk with the machine in case you need to do a reinstall. Vista has 6 different flavors, but most pre-installed systems have a recovery partition. Make a bootable recovery disk with that the first day you have the computer. Someday, you may thank yourself.
Johanna
You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Howdy;
thanks much
Looks is window dressing. its whats inside (and fixed) that counts. You should begin to think about Vista since MS has threatened to stop supporting 2k, XP in the near future. Im holding off switching to vista for another SP or more since i finally got 2k working great.
Btw, If youre going to buy the "refurb", check what warrenties/guarantees comes with it. If it doesnt come with a warrenty/guarantee, i would think 2x about it. granted, nothing may go wrong w/in the warrenty period, but if it does, it would be nice to have them flip the bill instead of you. Especially since youre not PC savvy. also, find out if its a local outlet, if they will support that warrently/guarantee either that you will have to ship it back.
also, if possible, i would opt for a desktop. cheaper, easier to work on and parts not as expensive. i know alot of people love laptops, but you have to consider how much are you actually using the "portabililty" aspects of the unit?
Riding is a partnership. The horse lends you his strength, speed and grace, which are greater then yours. For your part you give him your guidance, intelligence and understanding, which are greater then his. Togeather you can achieve a richness that alone neither can.
- Lucy Rees, The Horse's Mind
Personally, I am honestly thinking about a switch to Linux if I decide to get a new computer. With some of the emulator programs like WINE I think I will be able to continue to use most of all the software I currently use.
Refurb, by a mfgr. usually means whatever was wrong has most likely been fixed. Refurb from a private entity could mean anything. Everything in a computer can be replaced usually plug and play nowadays. Fairly simple, but the companies don't want the public to know how easy it really is. I ain't all that smart, but have built 2 desktops from scratch that have worked great for a long time. If it is a name brand that has a good rep., and the price is good, you should not have a problem. It may be my luck, but as far as warranties go, everything I have owned always breaks the day after the warranty expires!
