Thanks All,
I tried to quote each of you but the system won't let me, I didn't know there was a limit to the number of posts you could multiquote. I appreciate all the kind comments. Some of you mentioned the two tone dye job, I use a method to achieve that and I've never heard anyone else talk about it. I do it with Neetsfoot Oil. I coat the piece front and back pretty heavy and I don't burnish the edges until after I dye, so I also make sure I oil the edges well. then I let it dry, oiling the edges causes the oil to be "heavier" on the edges so that when I apply Fiebings Antique Dye the edges are darker than the middle and it has a separate benefit of the sling or belt being extremely flexible and feel really good. This method is totally random and isn't as controlled as sunbursting with an air brush, but I like the effect I get and apparently some of you do as well, if you wan't to use this method I recommend doing some tests on scrap before committing to an actual project. One note, if the oil drys evenly, then I apply more to just the edges, wait a short time and then do the dying.
Thanks,
Chief
"Life's too short to carry ugly leather"
Very nice! I like the clean and polished design: Not too sparse or overly worked, and your deer is perfect.
  • 2 months later...
Very nice work. I like the simple center to edge value gradient of the color. Did you draw the deer head yourself, or is there a template available?
I use several deer heads, this one is from a picture in a carving book I think, google or yahoo images and look for "Deer Head Line Art" you'll get plenty of them. I always look for line art when I need to find a new graphic to carve.
Chief
  • 3 weeks later...
Colt, these work very well also.
http://sewingnetwork.net/supply/index.php?main_page=product_info&products_id=265&zenid=8968622ecc863892ed47174839473b90
They are "zipper stops". I get mine from Zack White but I can't find them on the site.
THanks
  • 4 weeks later...
The staple that keeps your belt loop together is called a "slide loop staple".
Beiler's Manuf. & Supply Ronks, Pa. 71seven- seven six8- zero174
Page 64 Item both items are 3/8ths wide: item #10500 solid brass: item #10501 Stainless Steel. $25.25 per thousand.
