Members Hewy Posted October 4, 2014 Members Report Posted October 4, 2014 Cutting a perfect circle, to make a disc is difficult. Other than a stamp cutter what methods or techniques are known to do it ? The size I want to cut is about 2" to 3" Quote
Members Wild Bill46 Posted October 4, 2014 Members Report Posted October 4, 2014 I would have to agree, circles are hard to cut out. I simply use a string to measure or mark with, and then its up to you A Head knife works good sharpened razor sharp, or, You might carefully use a very sharp trim knife, scissors/shears will also work, But, Dye cutting seems to be the most useful idea, If you had a round dye the size you want to achieve. However, I do Not recommend Rotary cutting for rounds. I'm not much help, I'm afraid, I still struggle there too ! Good luck. ---- Wild Bill46 Quote
Members Chain Posted October 4, 2014 Members Report Posted October 4, 2014 Just buy precut round coasters Quote
Members billybopp Posted October 4, 2014 Members Report Posted October 4, 2014 I use an Olfa circle cutter if the leather isn't over 8ish ounces. If I can't have a pin-prick hole in the center for some reason, I put a piece of scrap leather there to stick the center pivot point needle (or whatever you call it) into. They come in about three or four sizes .. I think I've got the smallest one that maxes out around 3 or 4 inches. Hope that helps Bill Quote
Members 25b Posted October 4, 2014 Members Report Posted October 4, 2014 I use one like these...works great... http://www.sheridanleather.com:80/Unmarked_Circle_Cutter_p/dt-875-d.htm= http://www.sheridanleather.com:80/WM_Johnson_Circle_Cutter_p/dt-1338-d.htm= Quote
Members Hewy Posted October 4, 2014 Author Members Report Posted October 4, 2014 Nice tips on the tools. I like the Olfa rotary type seems it would take less downward pressure to hold in place. Thanks all Quote
Members Dwight Posted October 4, 2014 Members Report Posted October 4, 2014 The best way is with a punch, . . . you can use a clamp to squeeze it down and cut the leather. If you don't have a punch the right size, . . . get a piece of hard board or metal, . . . the size of the circle you want. About 1/16 to 1/8 inch thick is best. Clamp it to a table, . . . with a cutting surface under it, . . . your leather between the circle and the cutting surface. Strop your razor knife really sharp, . . . Run your razor knife around the outside. ONLY GO ONE WAY !! I know it sounds foolish, . . . but if you try going both ways, . . . most of the time you'll wind up with a "tail" on your circle. Going only one way erases that, . . . most of the time May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
LNLeather Posted October 5, 2014 Report Posted October 5, 2014 (edited) When I started doing leather work I started out making coasters and I used a really neat gizmo that cut leather in perfect circles... much better than I could ever do by hand. I got it at misterart.com ( right now they cost $22.85 and $3.76 for a pack of 40 refill blades) It will cut perfect circles in fabric, paper, mat board, cork, leather, veneer, linoleum and most other materials up to 1/4 in. thick. Capable of cutting circles from 3/4 inches up to 6 3/4 inches and Includes 5 blades, 2 blade holders and a centering guide. If you want to make even larger circles - They also make a Beam Slide Extender ($10.46) that allows cutting of even larger diameter circles . The Beam extender is 9 in. long and can cut circles up to 15 3/4 in. LION Ev-R-Round Perfiect Circle cutter (You might also find this interesting if you want to stamp letters in a circle) Hope this helps..... Edited October 5, 2014 by LNLeather Quote ~Cheryl There are many things in life that will catch your eye, but only a few will catch your heart... pursue those...
Members Wild Bill46 Posted October 5, 2014 Members Report Posted October 5, 2014 Side note; Thanx - 25b and Cheryl This helps me , I had no idea these tools existed ! Thanx to Dwight as well for your idea to cut circles. I re-read my post to myself and thought , I never should have even posted Ignorance, Sorry guys ! Quote
