Members Gregspitz Posted November 26, 2014 Members Report Posted November 26, 2014 was making a watch strap kind of in a hurry (should not do that!) last night and my techsew 2750 pro skipped one stitch. never happened before same leather horween and 69 bonded nylon with a 16 needle..but I probably did not let the contact cement dry enough prior to sewing...anyone else have that happen or am I off??? no tragedy..I pulled the stitch and retraced the holes and amazingly the machine did a great job fixing it and followed the holes exactly using the laser guide.. Quote Greg Spitz MD,FACS Custom Watch Straps 922Leather Gregspitz@922Leather.com
Moderator Wizcrafts Posted November 26, 2014 Moderator Report Posted November 26, 2014 Yes, tacky cement can cause skipped stitches. Ditto for Venture leather tape. Since I use the tape a lot, I switched to titanium coated needles on both patchers and on my long body Singer 139 walking foot machine. Unfortunately, there aren't any available for the big 441 clones yet. You may be able to compensate by using lubricated thread. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Gregspitz Posted November 26, 2014 Author Members Report Posted November 26, 2014 thanks so much...I won't make that mistake again.. have a great holiday Quote Greg Spitz MD,FACS Custom Watch Straps 922Leather Gregspitz@922Leather.com
Members Colt W Knight Posted November 26, 2014 Members Report Posted November 26, 2014 I have had problems with that too. I had to start being more patient, which is pretty tough to do. Quote
Members cleanview Posted November 28, 2014 Members Report Posted November 28, 2014 Are there other scenarios that would cause skipped stitches? To much cement? or others that one should be aware of? I am just learning my machine Quote Amarillo Texas bambamholsters.com
Members Constabulary Posted November 28, 2014 Members Report Posted November 28, 2014 Are there other scenarios that would cause skipped stitches? To much cement? or others that one should be aware of? I am just learning my machine Oh yes, there are several! F.I.: too much space between hook tip + needle scarf, broken / worn hook tip (at last the same problem), needles not insert correctly, needle / hook timing is off, wrong needle system, needle bar too high or too low (thats more or less the timing), too thick needle for the thread (loop will not form properly), needle is deflected by the needle deflector... These are all reasons why the hook can probably not catch the loop. Or sometimes even a combination of two reasons. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members cleanview Posted November 28, 2014 Members Report Posted November 28, 2014 Thanks. I knew that I knew nothing about sewing with a sewing machine when I ordered it.........and after having it a week or two I realize how much more I do not know than I thought. Learning as we go Quote Amarillo Texas bambamholsters.com
Members Gregspitz Posted November 28, 2014 Author Members Report Posted November 28, 2014 It will take some time to become one with the machine! Try to enjoy the ride. Quote Greg Spitz MD,FACS Custom Watch Straps 922Leather Gregspitz@922Leather.com
Members Tejas Posted November 28, 2014 Members Report Posted November 28, 2014 Attached is a 25 page Sewing Machine Troubleshooting Chart that lists 31 causes and solutions for skipping stitches. sewing_troubleshooting_chart.pdf Quote
Members cleanview Posted November 29, 2014 Members Report Posted November 29, 2014 That chart is priceless Quote Amarillo Texas bambamholsters.com
