post-23581-0-36615200-1418384349_thumb.j
It has done this since the day I got it. But I can not figure it out for the life of me.
As the "arm" comes down, there is slack in the line and it will wrap around the bar after the disk (as pictured). It will usually just act like tension is super tight and I look up and the thread will have wrapped around as pictured here. BUT When I use the little 138 thread it has started getting double wrapped around the pigtail between the bar and the arm and that actually locks it down (one time the needle got pulled out or it breaks thread)
Obviously. I am new with a sewing machine, trying to refrain from typing "thingy" but hope I have described the problem. It just seems like that slack should not be there when the arm is on the down swing......but I just don't know.
Oh! this picture was staged and not one of the actual mishaps. I guess that could be important.
Amarillo Texas
bambamholsters.com
When you thread your machine do you wrap around the lower tension(one in pic) 1 & 1/2 times?
Also the arm you thread through is called a takeup lever & you always want to make sure it is @ the top when you start & stop sewing.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
yes on the 1 1/2 times
and I do make sure the take up arm is at top
Amarillo Texas
bambamholsters.com
Is the spring working, I had to adjust mine.
The distance between the end of the screw and the nut on my machine is 5/32".
post-19342-0-74236400-1418394711_thumb.j
See image below, this is how Juki puts this thread take up stud with the bend on the end. I'm thinking this would prevent your upper thread from getting wrapped around this stud like you are showing.*
*I'm not trying to knock any machine setup or sold by anyone, and I may have sold some Juki TSC-441 copies that have the same stud with no bend, not sure. Just trying to help and share here.
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
The distance measure 1/4 inch.......
I am really unclear as to what that particular nut adjusts. I have been told one thing and read another. From tests, it seem to affect the knot position, but still confused about that. I have done LOTS of adjusting to observe the changes that it makes in the sewing.
the diagram does not ,make any sense to me since my machine is the only one I have seen
Amarillo Texas
bambamholsters.com
Maybe your thread is twisty. This does happen from time to time. Twisty thread loops over posts and guides until it binds in something. Try this and see if it helps:
  • Remove the top thread
  • Go to the spool on the thread stand and let the thread hang loose
  • If it coils hard, twist it in the opposite direction one or two turns.
  • Feed the end through the nylon guide above the cone
  • Feed the thread through the top hole in the top post in the top
  • Make 1 turn toward the back
  • Feed it through the bottom hole so it points to the left
  • If you have a lube pot, feed through its holes, in and out
  • Thread the rest of the way as per instructions with machine, or on YouTube
Adding silicon thread lube to the lube pot also helps subdue twisty thread.
All this may add to your top tension and bring the knots up too high. Compensate first by backing off the top tension adjuster, then the secondary adjuster. The last one to adjust is the bobbin tension, which should have a smooth pull at medium force, depending on the thickness and stiffness of the work.
Posted IMHO, by Wiz
I have had that problem with some kinky thread. I fixed it by extending the length of the pin with piece of heat shrink tubing about an inch long.
That would do it, too. Same as the bent back piece on the Juki, it just has to work, and that would help. Other models have a closed loop that I've seen.
I will try and see if the thread is twisty or kinky as described
Thanks for your comments
Amarillo Texas
bambamholsters.com
