Members cleanview Posted December 17, 2014 Author Members Report Posted December 17, 2014 ok thank you Quote Amarillo Texas bambamholsters.com
Members cdthayer Posted December 17, 2014 Members Report Posted December 17, 2014 One thing that hasn’t been mentioned is overloading the bobbin with thread. I finally figured out that I was doing that to myself. It’s natural to try getting as much thread on the bobbin as possible to avoid running out of thread or having to load the bobbin more often. But too much thread on the bobbin can cause binding when the thread pays off of the bobbin, and can create havoc with normally balanced thread tension.Overloaded bobbin means that the thread layers extend out past the rims of the bobbin. I’ve gotten to the point that I make sure they even stop short of being even with the rims, just to make sure the thread won’t contact the bobbin case when the bobbin turns.I don’t know if this could be any of your problem, but if you’ve got a freshly wound bobbin in and suspect it could be contributing to the problem, simply pull a couple of feet of the bobbin thread out, cut it off, and try sewing again.CD in Oklahoma Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Members shoepatcher Posted December 17, 2014 Members Report Posted December 17, 2014 cdthayer, That is correct. Most bobbins on industrial sewing machines should be filled only about 85% of capacity. That is what I have read from a lot of manufacturers over the years. By only filling a bobbin to that amount, you are less likely to overfill the bobbin and cause any tension issues in the bobbin case. glenn Quote
Members cleanview Posted December 17, 2014 Author Members Report Posted December 17, 2014 cool Quote Amarillo Texas bambamholsters.com
