These things only happen to me after everyone has gone home for the day! :rolleyes:
I just tried using my CB3200 in reverse. I was through my 23rd piece for the day where I had only been using the 'Poor Man's Reverse' out of pure habit.
I placed the machine in reverse after the needle bar was at it's highest point. Pushed down on the pedal, the needle moved inside the hole and broke the needle thread!
Any suggestions other than "Don't use reverse tonight"? :lol:
Have you tried changing out the needle making sure it is lined up perfectly? Maybe your top tension is too tight? Is the thread getting caught or wrapped around something? What size needle and thread are you using?
C4 users are told to stop the machine once the needle has risen 1/4 inch or so before reversing. It will actually work just before the needle leaves the leather. Never tried the top of the travel.
No dice. This time ... when I put it in reverse. My needle thread got caught up in the Bobbin Shuttle and I had to clean out the rat's nest!
that's what I was gonna suggest.. look for some obstruction in the shuttle area .. it grabs the thread, which then twists wrong (because .. duh.. reverse :) ) and then.. well .. you see
5 leather patterns
I always shift to reverse after the needle has just started back up from Bottom like was said, the loop should have already been picked up at that point. Mine hasn't failed to work yet. But I agree that there might be some issue with the needle or the bobbin shuttle as was said also. The only problem I had (only once) was it started fraying and breaking the top thread in forward or reverse, after checking every thing I found that although the needle looked good it was slightly bent and wasn't exactly lined up anymore. I replaced that needle, made sure it was aligned perfectly and it is still sewing well. Might be a worn or misaligned needle.
Chief
"Life's too short to carry ugly leather"
It's a brand new machine! I have sewn less than 6 hours on it.
rooster, if its any consolation My new 3200 has broken thread last week when I close out a circle and stitch over, perplexing to figure out. No help, but as t least you know your not alone.
Amarillo Texas
bambamholsters.com
Few Questions:
1. Did the reverse ever work properly?
2. Have you changed needles and thread since it arrived? What size needle and thread.
3. What happens if you manually reverse the machine without flipping the lever.
4. Do you have a washer under the stitch lever plate?
Cya!
Bob
Edited by BDAZ
