Hey yall
Just a quick question. What is the best way to stiffen leather? I have some 2-3 Oz leather and am about to start doing some pouches. I need to stiffen the bag part. Not rock hard but hard. Any ideas??
Thanks
hi, the only thing i can think of is to dampen it and then bake it, put it in the oven on a very low heat and check every ten mins. hope this helps ;-)
Use heat wet leather if it is just certain areas you can use hair drier just not too hot if using over 170 is about as low as they will go.
Papaw
Indiana Calumet Area Leather Guild
Happy to be old enough to know better, but young enough to still do it !!
To stiffen leather for a holster, I just use hot tap water for molding. It's 8-9 ounce so I'm not sure how that'll work with 2-3 ounce. I'm reluctant to put it in an oven or use a hair dryer on it for fear of drying it out.
Keep on Chooglin'
Check out my YouTube Channel, comment and subscribe for updates
https://www.youtube.com/channel/UCOM3hbruUKHov9kquIxXKlA
http://www.goodsjapan.com/leather-hardeners-36-c.asp
I've used the water based product a few times with good results. no bad odor didn't darken even white deerskin when dried yet did harden enough to hold a scrunched up test shape and still flex.
I am also trying a few other ways to harden leather. Did a dip of several types of leather in warm water with ammonia until bubbles stopped rising, then wrapped around some jars/cans and used vet wrap to hold until dried. 2 were still damp the next day and placed in low oven for about an hour still on the molds. an oil tanned leather held well quite stiff but flexed enough the idea may work for some cuffs. the veg tan didn't harden as much and the deerskin, same type as used with the commercial product, didn't change much at all.
One guy who has a lot of youtube videos on leather, think he's in england, did a review of the leather products from this site. overall very positive. I think he mentioned that japan is strict on chemical toxins in consumer products and nothing on the site had much of a warning. I don't know what is in it but it did work, didn't stink and the small bit I got on my hands didn't cause any irritation
I did try to heat it in the oven after wetting the first. Kinda scorched it an shrunk it a bit. Also tried fabric stiffer, not that great on this thin leather. I read somewhere on using wood hardner. Gonna get some and try it. Will let yall know.
A hair dryer gives you a lot more control over heating the leather, since you can hold it whatever distance works best. As long as you pay attention you won't scorch or shrink the leather.
"Everyone with telekinesis, raise my hand!" -Repairman Jack
Usually drying wet formed products i the sun is no problem but every once in a while I have a larger order and it rains! I have a fron load tryer which came with a rack for drying objects like shoes. When sun drying mt items will reach 140F which I find ideal. I use the very low heat setting in the dryer and it works perfectly.
Tiara: never use ammonia on leather!! Those bubbles you saw were a natural reaction to the acids in the leather which are critical for longevity.
Cya!
Bob
Tankerman I don't think you've ever dried jerky in an oven. :) It requires just the lowest setting which may be as low as 120-150F and temps will be higher near the top than the lower racks.
Drakkon, the hair dryer tip is one of the things I'll be experimenting with later today or tomorrow. A friend has asked for a cuff in a lovely pale blue baby gator back and would like it asymmetrical and formed so it doesn't slip around much. Her wrist is close in size and shape to mine. I plan on trying some thin veg tan shaped to my wrist. Hoping to get it rigid enough to use without a metal cuff inside. Grain side towards the arm, flesh to flesh for gluing. The gator is pretty enough that stitching would detract from it. If that works, I'm thinking of trying for spiral armlets that way. Will get your samples sent out soon. The last thing I was waiting for came in. :)
Bob, the dilute ammonia method is mentioned several times on the board. Your comment brought up several points. One discussion on using ammonia indicated that this worked by lifting oils out and that alcohol would do the same. But I did wonder about the long term affects of an alkali on the leather. As it was quite dilute, I think its 1 part ammonia to 8 parts water, and enough long time members were mentioning it, it was worth a try. And with ammonia/urine having a long history in leather making, didn't seem too likely to be a problem. I play the Irish bodhran hand drum. One method of treating the drum skins is to bury it in a manure pile for a while. Those skins are supposed to play nicely if you can stand to do so before the stink dissipates. :) I had wondered about the chemistry of the ammonia method. As I started to dig around I found this link http://www.personal.utulsa.edu/~marc-carlson/leather/hl.html and http://www.leatherchemists.org/forum/forum_posts.asp?TID=230&KW=stiffening
The bubbling might be due to a chemical reaction but at such a low dilution I'm more likely to think it was simply due to the bubbling out of air as several references to soaking leather or drum skins state to soak until all bubbling stops to be cure it is saturated.
The question of being careful what we use on leather is important to long term results. Acid/alkaline balance, oils/fats that oxidize, dyes that may not take--http://www.dharmatrading.com/cgi-bin/search.cgi?query=reactive or http://www.dharmatrading.com/dyes/dharma-acid-dyes.html?lnav=dyes.html but there is mention that these dyes are sometimes used on leather.
I'd be cautious of using a product made for wood on leather without having heard from those with more experience or a good idea of any differences in the chemicals.
I'm thinking of trying this http://www.amazon.com/gp/product/B002BWF5PK/ref=ox_sc_act_title_4?ie=UTF8&psc=1&smid=ATVPDKIKX0DER#product-description-iframe as it is non corrosive and moisture curing. What? a low stink flexible adhesive that will cure faster in higher humidity? Hmm, what if I could take 2 pieces of leather I want to adhere, mist with water, spread this stuff on them, slap them together and align, wrap or clamp together and let sit for a few days? It might be worth the wait.
I might sign on the leatherchemists forum to ask if there is a chance this stuff might not be wise down the line.
Good point about the air bubbles. I occasionally use vinageroon and neutralize with baking soda and it is definitely CO2, not air I see. A test would be to soal the leather in water, drain and then apply the ammonia...bubbles = CO2 = PH Change.
BTW I used to build bodhrans when I lived in Ireland. I buried the fresh skins in alum for a couple of weeks and the trick it to apply the wet skins to the rim. After drying once they are never the same. (I also play Irish tenor and and on my way to a session this afternoon)
As for glues, try one of the polyurethanes, which is moisture activated. I have never used it on leather but I imagine it would work well for for certain applications, not as flexible as RTV but it will penetrate and expand.
Cya!
Bob
