Members shadowryder Posted February 26, 2015 Members Report Posted February 26, 2015 Hi guys,I have recently bought one of these machines here in the UK.{used} I am slowly getting used to it but havent made anything with it yet. Any way whilst running some practice pieces of leather yesterday the machine jammed up and stopped, on investigation I found that a small screw had come loose on the shuttle and jammed up the mechanism,I reved this and screwed it back into where it came from thinking right ok again, How wrong could I be???? I found that while the machine ran the shaft that runs the shuttle does not turn anymore and following it back it gos into this centrifugal clutch which having read a bit is a safety clutch which kicks in to prevent damage, Anyhow I downloaded manuals etc I could find on the web but none of them tell me how to re set this clutch,, SO can anyone on here please Help me, IN the SIMPLEST terms possible cos I aint a techno head.with pics would be great. Thankyou in advance. Quote http://www.bat-shadow.jigsy.com/http://www.facebook....tShadowLeathers
Members Gump Posted February 26, 2015 Members Report Posted February 26, 2015 There should be a button on the arm, press and hold it down while rotating the machine backwards until the button drops down then rotate forward until it clicks and the clutch should be reset. Quote
Members Gregg From Keystone Sewing Posted February 26, 2015 Members Report Posted February 26, 2015 ... Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members shadowryder Posted February 26, 2015 Author Members Report Posted February 26, 2015 hi guys have tried that its not working "clutch" is just turning round the shaft and shaft not movingclockwise or counter CW is the same. thanks for your posts. Quote http://www.bat-shadow.jigsy.com/http://www.facebook....tShadowLeathers
Members Gump Posted February 27, 2015 Members Report Posted February 27, 2015 Flip the machine back and check the belt and clutch assembly. It is possible to break a belt (but unlikely), and it is possible that the little spring that pushes the locking dog in place broke or came out of place. you can also check that the toothed wheel that the button engages is not just spinning free on the shaft. Quote
Members shadowryder Posted February 28, 2015 Author Members Report Posted February 28, 2015 (edited) The small wheel on shaft is tight and connecting on button but the shaft is not turning when the clutch turns with the belt. do you have a diagram of how small spring etc is attached please as i found the spring fipped off in bottom of machine space, sorry for being a bit dumb on this but I am a bit of a technophobe. thanks again. Edited February 28, 2015 by shadowryder Quote http://www.bat-shadow.jigsy.com/http://www.facebook....tShadowLeathers
Members shadowryder Posted February 28, 2015 Author Members Report Posted February 28, 2015 OK Guys thanks to your tips and this video i found { } I have managed to re set the clutch and basically re set the timing on the machine,It is now sewing BUT I am now finding that I have to pull the leather thru the machine as even though the top and bottom feet are moving they will not feed the fabric thru on its own forward or reverse,it sews in n out the same hole unless I pull the leather thru by hand, HELP PLEASE,, sorry for being a dumb ass but I am trying to learn,,, thanks again. Quote http://www.bat-shadow.jigsy.com/http://www.facebook....tShadowLeathers
Members catskin Posted February 28, 2015 Members Report Posted February 28, 2015 (edited) I am not familiar with that exact machine but it sounds to me like something is not letting the foot go all the way down to grab the material in order to move it. Or is it possible you have accidently got the forward/ reverse in the middle so it doesn't move the material? Edited February 28, 2015 by catskin Quote
Members shadowryder Posted February 28, 2015 Author Members Report Posted February 28, 2015 the top foot is leaving quite a deep impression on the leather when going up n down also I have tried to alter the foot pressure softer and harder without any difference. I do not think it possible to "neutral the forward reverse on this machine but May be so will try to check it tomorrow. Thanks any other suggestions gratefully received Quote http://www.bat-shadow.jigsy.com/http://www.facebook....tShadowLeathers
Members Constabulary Posted March 1, 2015 Members Report Posted March 1, 2015 Pulling material through makes no sense except you have a darning machine. There actually is a variant of this machine which is made for darning. Is it really sewing when you pull it through or is it just making stitches w/o thread? Maybe you can post some good detailed pictures of your machine and maybe some sees right away what is wrong with it... ATM I only could imagine thta the stitch lenght adjuster is the problem Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
