Members Tokarsky Posted April 16, 2015 Members Report Posted April 16, 2015 (edited) I think this is the first real thing I'm proud of producing. Used 2/3oz Hermann Oak Vegtan, Fiebings Pro Walnut Dye, and Brown .6 Ritza 25. Man how the lighting affects the color in the picture... Edited April 16, 2015 by Tokarsky Quote
Members verus22 Posted April 16, 2015 Members Report Posted April 16, 2015 Looks good! Very clean lines, nice and straight. And I feel your pain with the lighting!! Quote "Excellence is the gradual result of always striving to do better." - Pat Riley
Members MonicaJacobson Posted April 17, 2015 Members Report Posted April 17, 2015 Nice burnish! Quote http://monicajacobson.com/ https://www.etsy.com/shop/TrimGoTrix?ref=si_shop
Tinneal Posted April 17, 2015 Report Posted April 17, 2015 Beautiful! And wonderful burnish. Mind sharing how you did it? Quote Leatherwork Portfolio | Etsy Shop
Members Tokarsky Posted April 20, 2015 Author Members Report Posted April 20, 2015 Beautiful! And wonderful burnish. Mind sharing how you did it? Thanks. So obvious step one is to cut and glue all the pieces as close to perfect prior to stitching. After stitching, I even up all the edges with my dremel and a sanding bit. I then use an overpriced tandy edge beveler to edge the now floppy edge corners. Next, and I hated to admit to myself that this made a difference was wet sanding by hand with 400 grit paper... I always thought wet sanding was pointless, I was wrong and dumb. After that moisten with gum trag and hit it with my "ghetto-cocobolo" dremel burnisher http://i.imgur.com/4UV1TfJ.jpg that gets it pretty good, but the last thing I started doing was rubbing some plain beeswax right on the edge and using some canvas to make it hard and shiny. Hope that helps. Quote
King's X Posted April 20, 2015 Report Posted April 20, 2015 I just bought that Walnut color and have been very content with the shade. Nice work....keep it up! Quote Greetings from Central Texas! The Grain Side Up blog #TheGrainSideUp
