Hi all,
Tried googling but could not get a definitive answer regarding needle system of Pfaff 335-17.
The dealer who sold it to me told me it was 135-16.
But the dealer whom I usually buy supplies from sells 190LR needles for this machine.
Looking primarily for the size 18-24 leather point needles, but going to need some smaller textile needles too. Could leather and textile needles be of a different system for this machine?
Appreciate your input!
Edited by DrmCa
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Does that mean both 134 and 135 are good?
Pardon my ignorance, but what is the difference?
See attached, hope this helps.
post-14272-0-71010800-1432301281_thumb.j
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
You can use 135-17 needles with this machine. For further info I suggest the Beissel conversion chart for needle systems.
Thank you all for setting me straight!
  • 3 weeks later...
Does anybody know what is the largest size of needle 335-17 should work with?
I tried size 24 but the needle alone could not pass through the slit in the hook. Looks like that it would not pass through the hole in the feed dog if I used saddlery thread.
It is not alignment - trying from the bottom the needle's tip gets stuck in the slit.
Does it mean I am limited to size 22?
Edited by DrmCa
Yes, unless you can find a feed dog with a wider hole, or file yours out, then reposition the hook or needle deflector.
Posted IMHO, by Wiz
  1. Needle system: ............................................................................................................ 134 - 35 Needle thickness (Nm) in 1/100 mm: ........................................................................... 80 - 100
This is from their instruction book
