Members DrmCa Posted June 2, 2015 Members Report Posted June 2, 2015 There is a tapered grove on the left side of the needle bar as in the attached picture. Should there be also a thread guide as for example in Juki 553 to guide the thread onto that grove? I did some googling but could not find any hi res pictures of the needle bar with any guides. Thank you! Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Members shoepatcher Posted June 2, 2015 Members Report Posted June 2, 2015 DrmCa, Yes, there should be a thread guide on that needle bar. I will check and see if I can find one. Send us a pic of the other side of the needle bar. glenn Quote
Members Gregg From Keystone Sewing Posted June 2, 2015 Members Report Posted June 2, 2015 See attached, it appears the needle bar thread guide is broken off from the needle bar. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members DrmCa Posted June 3, 2015 Author Members Report Posted June 3, 2015 Does not look broken, maybe grinded off cleanly. Or may be there are different styles of the needle bars out there? Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Hockeymender Posted June 3, 2015 Report Posted June 3, 2015 Every 335 I have had (that's been several) have all had a thread guide at the bottom of the needle bar. That said, I guess there are bound to be exceptions to the mainstream however. Quote Regards, Joe Esposito www.hockeymenders.com instragram: @hockeymenders.com
Members Gregg From Keystone Sewing Posted June 3, 2015 Members Report Posted June 3, 2015 Does not look broken, maybe grinded off cleanly. Or may be there are different styles of the needle bars out there? Interesting, I'm not really sure, Pfaff does offer for some subclass machines a needle bar without guide. Maybe it was replaced with one of these? Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members shoepatcher Posted June 3, 2015 Members Report Posted June 3, 2015 The needle guide is was indeed part of the needle bar. Yours was there and broke off and was reground to look smooth. You might be able to get a Juki or Singer small needle guide to fit. Otherwise, it means a new needle bar! I would try the Juki or Singer bottom needle guide first. Cheaper. It may require you using the needle set screw to hold the guild on as well as the needle. glenn Quote
Members Gregg From Keystone Sewing Posted June 3, 2015 Members Report Posted June 3, 2015 Juki and Singer needle bars are not going to work here, find a suitable replacement, or just use the machine as it is, many machines with broken needle bar thread guides are out there working just fine. Not ideal, but not worth ripping the machine apart for either unless you feel necessary. Quote Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
Members Constabulary Posted June 3, 2015 Members Report Posted June 3, 2015 I think Glenn meant the thread guide of the Singer 111 needle bar. Like this one: http://www.ebay.com/itm/Singer111-Consew-225Needle-Bar-Thread-Guide-240499-2pcs-/270478405527?pt=LH_DefaultDomain_0&hash=item3ef9c4ef97 Another idea would be the Singer thread cutter, it slides over the needle bar and you can use it as a thread guide. I don´t know if these are different types for different diameter needle bars but this would be an easy fix. http://www.ebay.com/itm/SINGER-SEWING-MACHINE-221-FEATHERWEIGHT-THREAD-CUTTER-SIMANCO-/361176831515?pt=LH_DefaultDomain_0&hash=item5417d1161b Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Andrew Chee Posted June 3, 2015 Members Report Posted June 3, 2015 If you don't want to replace the needle bar ( had did when my thread guide broke and it took me a while to retime the thing) you could try wrapping a zip tie around the needle bar right there and using that as a thread guide. Might work ok... Andrew Quote
