hi all
my name is dedi
i want to ask you all about gutterman thread
does anyone have try buy it?
this is the web that i found
https://www.guetermann.com/shop/en/view/content/
i dont know they thread size
i need in 0,6mm thick
i attach a picture the thread that i want
thanks
dedi
Edited by naturalisme
  • 2 weeks later...
Maybe Ebay Germany. Is it your thread spool? Usually they have the thread name, a colour number and thread thicknes mentioned on a small sticker on the inside of the spool.
I´d assume the therad name is TERA (Polyester thread)
Edited by Constabulary
an alternative thread could be Aman SYNTON or SERAFIL (same thread afaik - SYNTON is the old name) in colour 1002 or 1003.
  • 2 weeks later...
That's Gutterman upholstery thread. It's ~0.01"/.25mm off the spool.
thanks for the pict. if i need in 0,5-0,6 thread what do you suggest?
i have try serafil. now i want to compare serafil with gutterman. and if you know where to buy bourbon nylon coats i'd like to try it also..
thanks
  • 2 weeks later...
Thread Exchange carries lots of poly and nylon thread in all kinds of sizes but the color hit and miss. When the project can afford it, I order a couple of colors that are very close to what I think they describe their thread as, and one usually matches.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
Guterman upholstery thread comes in that one size, so it's not going to be suitable. If you're looking for nylon or poly, DrmCa's suggestion is good.
If you want linen, try Crawford's Irish linen. It comes in a great variety of colors and plies that will come close to what you need. I get it from Royalwood in the US.
I have no idea about Indonesian sources.
If you're making watch straps, .6mm is an enormous thread.
yes, now i use crawford irish linen waxed. thats a great thread.
