Members kevinamc Posted July 26, 2015 Members Report Posted July 26, 2015 Hey everyone, just started doing some sewing on my day off and I'm finding when i try to bring the bobbin thread up through with the needle it doesn't wind properly and wraps around the bobbin case it is super frustrating and i can't figure out whats going on. I also noticed that my bottom stitch acts up occasionally and bulks up or doesn't complete at all, i am thinking the issues are related. Just looking for some advice so i can get back to working. Thanks for your time! Kevin Quote
Members kevinamc Posted July 26, 2015 Author Members Report Posted July 26, 2015 and now i can't seem to turn the hand wheel at all its extremely jammed up or something Quote
Members Constabulary Posted July 26, 2015 Members Report Posted July 26, 2015 (edited) I´m on the run - just a few fast hints.... You first have to remove the bobbin case and remove all the jammed thread from the hook era and reinstall it. Do you have a manual for your machine? Have you threaded the machine correctly and insert the bobbin correctly thread should come off the bobbin from the left side. Have you checked the needle bar hight and timing of your machine? Your needle bar has timing marks (hopefully). Upper mark is for needle bar at BDC and the lower mark for the point where the hook tip should meet the needle scarf and grab the loop of the upper thread. For a quick aid download the manual for a Consew 227 - this is a different machine but the technical instructions are very good and are almost the same as for your Singer 111w155 have to run - sorry Edited July 26, 2015 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Tejas Posted July 26, 2015 Members Report Posted July 26, 2015 Chapter 4 of the manual in the following link might be helpful. http://militarynewbie.com/wp-content/uploads/2013/11/NAVEDTRA-14217-Aircrew-Survival-Equipmentman-1-C.pdf Quote
Members kevinamc Posted July 26, 2015 Author Members Report Posted July 26, 2015 thanks for the info! ill have to investigate the removal and installation of the bobbin case as everything else appears to be in order. is it a difficult job? Quote
CowboyBob Posted July 26, 2015 Report Posted July 26, 2015 Try taking the bobbin out(so the thread is out of the way)unthread the needle too,put some oil all the way around the outer part of the bobbin case & it might loosen up w/o having to take it apart.You might need to take the belt off so you can rock the handwheel back & forth. When you first started did you hold onto the needle thread to get the bobbin thread through the feed dog ? Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Constabulary Posted July 27, 2015 Members Report Posted July 27, 2015 Chapter 4 of the manual in the following link might be helpful. http://militarynewbie.com/wp-content/uploads/2013/11/NAVEDTRA-14217-Aircrew-Survival-Equipmentman-1-C.pdf Thats much better thanks for the info! ill have to investigate the removal and installation of the bobbin case as everything else appears to be in order. is it a difficult job? You just have to remove 2 screws - don´t lose em - better take a magnetic screw driver Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members kevinamc Posted July 27, 2015 Author Members Report Posted July 27, 2015 Thats much better You just have to remove 2 screws - don´t lose em - better take a magnetic screw driver IMG_0839.JPG Thanks a million for the info! you have all been a huge help in getting me back behind the machine Quote
Members kevinamc Posted August 2, 2015 Author Members Report Posted August 2, 2015 So i have removed the 2 screws that are pictured above, and the plate appears to move left and right fine but i cannot life it out of the machine. Where am i going wrong here? thanks in advance! Quote
Members Constabulary Posted August 2, 2015 Members Report Posted August 2, 2015 (edited) remove the needle plate and lift the small lever grab it and turn the boobin case little bit and sooner or later you have it. Good chance to remove lint or dirt under the needle plate when you see some Edited August 2, 2015 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
