Members Windrider30 Posted August 8, 2015 Members Report Posted August 8, 2015 I use bag stiffner from tandy...if its just something I am messing with i just use tracing paper or normal paper from my printer Quote
mlapaglia Posted August 9, 2015 Report Posted August 9, 2015 I use file folders, basically poster board. I get tons of it for free at work. But you also asked the best way. Draw them on a cad program and burn them with a laser. Perfect transfers. Same here. File folders. Quote The key to immortality is first living a life worth remembering. Bruce Lee
ChriJ Posted August 9, 2015 Report Posted August 9, 2015 I make patterns for woodworking out of 1/8" or 1/4 hardboard like they use to make pegboard but without the holes. I assume it would work for leather too. Chris Quote
Contributing Member JLSleather Posted August 9, 2015 Contributing Member Report Posted August 9, 2015 I make patterns for woodworking out of 1/8" or 1/4 hardboard like they use to make pegboard but without the holes. I assume it would work for leather too. Chris Masonite will work -- I used it 100 years ago. Changed to plexiglass about the same thickness after that, though, so I could see the leather under the pattern. Alternately, I have been known to mark the pattern, cut it out (band saw), and then keep the OUTSIDE, so that you lay it on teh leather and teh part you're cutting out is the part that's visible. Makes a bigger piece to store, otherwise it does work. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members Colt W Knight Posted August 9, 2015 Members Report Posted August 9, 2015 (edited) I make patterns for woodworking out of 1/8" or 1/4 hardboard like they use to make pegboard but without the holes. I assume it would work for leather too. Chris Masonite will work -- I used it 100 years ago. Changed to plexiglass about the same thickness after that, though, so I could see the leather under the pattern. Alternately, I have been known to mark the pattern, cut it out (band saw), and then keep the OUTSIDE, so that you lay it on teh leather and teh part you're cutting out is the part that's visible. Makes a bigger piece to store, otherwise it does work. I use hardboard/masonite for guitar building templates. I tried acrylic but the router bearings somtimes got hot and melted the acrylic, but I bet for leather working it is the way to go. The downside to masonite/hardboard templates is the edges begin to crumble in humid climates. So I always had a master template I kept in my sock drawer to remake the working templates every so often. I use manilla folders for my leather patterns now. If i had a pattern I used a lot, I would either make acrylic patterns or have a clicker die made. Edited August 9, 2015 by Colt W Knight Quote
Members SmokeyPoint Posted August 11, 2015 Members Report Posted August 11, 2015 For flat templates, go to Costco and look for the non-corrugated cardboard they use to separate layers of Gatorade cases on the pallet. They'll let you take them home for free, and they're almost as stiff as bag stiffener. Quote http://www.smokeypointleather.com
Members failghe Posted August 11, 2015 Members Report Posted August 11, 2015 I use my empty cardboard beer cases. Drink beer, recycle the cans, use the box for templates. Waste not. Quote
Members Mhicks Posted August 13, 2015 Members Report Posted August 13, 2015 I'm just getting started and have been laying out templates for things I want to make using Bristol paper. It is 100lb paper, it takes pencil very well and erases clean when you want it to. Its a little pricey but I just picked up a 19"x24" booklet with 15 pages for $15 at hobby lobby. Quote
Contributing Member JLSleather Posted August 13, 2015 Contributing Member Report Posted August 13, 2015 I'm just getting started and have been laying out templates for things I want to make using Bristol paper. It is 100lb paper, it takes pencil very well and erases clean when you want it to. Its a little pricey but I just picked up a 19"x24" booklet with 15 pages for $15 at hobby lobby. Bristol board works great. Just a tip.. you can probably get that same stuff at a print shop for less money -- just won't be paying for the packaging and a middle man. Quote "Observation is 9/10 of the law." IF what you do is something that ANYBODY can do, then don't be surprised when ANYBODY does.
Members chiefjason Posted August 14, 2015 Members Report Posted August 14, 2015 For flat templates, go to Costco and look for the non-corrugated cardboard they use to separate layers of Gatorade cases on the pallet. They'll let you take them home for free, and they're almost as stiff as bag stiffener. If it's the same style board they cover our pallets with at work it's fantastic. I keep a few every couple months. Bought time to grab a couple more. Just heavier than poster board but easy to cu with a razor knife. Stiff enough to hold up for a good bit of use too. Quote
