Members l2bravo Posted September 12, 2015 Members Report Posted September 12, 2015 So I am thinking about getting a machine. How is the 3200 thought of? I will be sewing mostly oil tanned, with some veg and latigo. All told, less than 20 oz. for the majority. i would love to hear some opinions, prior to making a mistake. Thanks for the help, Josh Quote
Members cleanview Posted September 12, 2015 Members Report Posted September 12, 2015 (edited) I bought my 3200 about 10 months ago..........It is my only experience ...........I like it. Edited September 12, 2015 by cleanview Quote Amarillo Texas bambamholsters.com
Members dfrensdorff Posted September 12, 2015 Members Report Posted September 12, 2015 I have one that I purchased this last summer and am still experimenting with it and learning its limits......Nice machine all in all...... Quote
Members Toolster Posted September 15, 2015 Members Report Posted September 15, 2015 Josh, I've owned my CB3200 for almost two years and the honeymoon aint over yet. It has never failed to pick up the bobbin thread and never missed a stitch. I run 277 thread top and bottom......mostly stitch holsters and thicker gun belts. I know it can be set up for a wide range of threads/needles (69-346) but I've only run 277. Last spring I purchased a flatbed CB0797 and it's great for my lighter work (dress belt, wallets, etc). That way I don't need to dumb down/readjust my CB3200 for the light items. I have yet to hear anyone complain about the CB3200. IMHO it's a great machine and very reasonably priced. Bob Kovar and Ryan Neels are both great resources if you ever need support. Quote JW My sewing machines (until I buy another one): Cowboy CB3200 Cowboy CB0797
Members 25b Posted September 15, 2015 Members Report Posted September 15, 2015 I've owned my CB3200 for almost two years and the honeymoon aint over yet. It has never failed to pick up the bobbin thread and never missed a stitch. I run 277 thread top and bottom......mostly stitch holsters and thicker gun belts. What does the back side of your stitching from your CB3200 look like? Care to share? Because mine looks like garbage and no one apparently has any ideas to offer to fix it. It's not a rat's nest....(I know how to use the machine correctly).....the back side stitches just look pulled in really tight, even with the presser foot pressure almost all the way off. I've seen other people post the same problem with their CB3200 on here and never get a solution either, so.....not sure why that is.. Quote
Members Toolster Posted September 16, 2015 Members Report Posted September 16, 2015 Here ya go 25b....First one the front, second is the back. This is a thick (16oz) belt. Not as good on the back but more than acceptable. Quote JW My sewing machines (until I buy another one): Cowboy CB3200 Cowboy CB0797
Members Nhfarm50 Posted September 20, 2015 Members Report Posted September 20, 2015 25b - that is the problem of have with both my Cowboy machines... The tension can be quite hard to get just right. When it is really loose on the back I have found that I am using too large of a needle for the thread I am using. That is the only complaint about my 3200 or The Cowboy Artisian clone. 25b - that is the problem of have with both my Cowboy machines... The tension can be quite hard to get just right. When it is really loose on the back I have found that I am using too large of a needle for the thread I am using. That is the only complaint about my 3200 or The Cowboy Artisian clone. Quote
Members msdeluca Posted September 20, 2015 Members Report Posted September 20, 2015 (edited) I get very similar results as Toolster and can dial in the tension on anything from sunbrella to 3/8" thick leather laminations. I always back off both upper tensions and then turn them up 1/2 turn at a time until the knot finds its way into the center of the material. I use Wiz's info below: From Wizcrafts: I try to match the size and breaking strength of the thread to the project. Plus, one has to choose a combination that conceals the lockstitch knots between the layers. So, here are some of my general recommendations for you.  For very thin and/or soft projects, 3 - 5 ounces: #69 thread with a #18 needle (below 441 practical limit. Round point only.) (8 /inch)  For thin projects, 6 - 8 ounces: #92 thread with a #19 or #20 needle (at practical bottom 441 limit. Round point only.) (7 /inch)  For 9 - 12 ounces: #138 thread with a #23 needle (typical, consistent 441 bottom limit. Smallest leather point 794 needle) (6 /inch)  For 13 - 20 ounces: #207 thread with a #24 needle (great for stitched belts, single and double leather) (5.5 /inch)  For 21 - 28 ounces: #277 thread with a #25 needle (5 /inch)  For 1/2" to 3/4": #346 thread with a #26 needle (4 /inch)  Extra heavily stressed projects, 3/4" to 7/8": #415 thread, with a #27 needle. (3.5 to 4 /inch) Another thing that I do is always wrap the thread 1.5 times around the lower tension so that the thread exits the tensioner next to the faceplate rather than away from the faceplate.... and don't forget to run the thread through the last hole in the bottom of the needlebar. Hope that helps, Mike www.conceptleather.blogspot.com Here ya go 25b....First one the front, second is the back. This is a thick (16oz) belt. Not as good on the back but more than acceptable.100_2976.JPG100_2977.JPG Edited September 20, 2015 by msdeluca Quote Michael www.conceptleather.blogspot.com www.temptedthreads@blogspot.com
Members jeffss Posted September 21, 2015 Members Report Posted September 21, 2015 Try the Global WF 9205 , just as good as the discontinued Adler 205 for 1/2 the price. Quote
Moderator Art Posted September 21, 2015 Moderator Report Posted September 21, 2015 25b and others with tension problems, Try reducing the bobbin tension a little and then readjusting the top tension for the lock to be in the center of the leather. I have seen machines where the top tension is so tight that you can play high C on it. The problem with the tight tension is that the tighter it gets, the less variance it takes to make big moves in the tension. In other words, less tension allows for more variance in the thread and other sewing factors. Now keep in mind that you need enough tension to keep a tight stitch, especially on the smaller thread you use. Art Quote For heaven's sakes pilgrim, make yourself a strop!
