Oh, no, I'm not going to sew holsters. But sometimes I need to sew 3-6 layers of 1-1.8mm leather. Now I'm sewing with vintage but angry hand-cranking sewing machine. And with some violence and lubricant it sews about 5mm of leather, so I supposed that Sailrite could do it better. But as I can see it would be better to think aboutan industrial machine. Just not sure if I can attach a crank to industrial machine.
  • 1 year later...
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
I am currently making a stitch down shoe with a Juki 1541 and it is struggling a bit. The material is 8oz boot sole and a 5oz shoe upper leather (both chrome and veg tan). Total thickness is about 3/16".
I have a few questions about what the best solution may be.
The machine does a good job once I get going. Can I change the pulleys out to get better low end torque? Is there a better or bigger motor I should go for instead of changing the gear ratio? Is there a better all around machine that is standard with the low end power that I need?
Thanks
Yes i agree a smaller pulley will help the torque available punching through.
Good day
Floyd
Thanks
What type and wattage motor do you have now? What is the diameter across the motor's pulley? Ditto for the machine pulley?
Posted IMHO, by Wiz
current pulley is a 3" and the motor is a small (looks pretty cheap too) dial adjusted servo motor. The 3/4 HP consew brushless servo is only 125ish on amazon. Is that a good step? My friend mentioned an EFKA but they are a bit more.
See if you can get a 45mm (1.75") or 50mm (2") pulley that will fit the shaft on your motor. This will give you a boost in torque and reduction in speed. You will need a slightly longer belt to reach the smaller pulley (~1" - 2" longer).
Posted IMHO, by Wiz
